Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 CORSAIR Cooling Hydro Series CWCH50-1 Intel Core i7-930 Bloomfield 2.8GHz LGA 1366 130W Quad-Core Rosewill Xtreme Series RX750-S-B 750W Continuous @40°C ,80 PLUS Certified, ATX12V v2.2 & EPS12V v2.91, SLI Ready CrossFire Ready MSI N250GTS TwinFrozr 1G OC GeForce GTS 250 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard60874158 windows 7 protools 8 003 rack protools 8 8.04 *************************************************S andra Report******************************************** **** SiSoftware Sandra Computer Model : Gigabyte X58A-UD3R Workgroup : WORKGROUP Host Name : nixon-PC User : nixon Processor Model : Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz Speed : 2GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Gigabyte X58A-UD3R BIOS : Award (Phoenix) FA 04/20/2010 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 6GB DIMM DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 2.43GHz (4.86GHz) Chipset Model : Giga-Byte Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.43GHz (4.86GHz) Total Memory : 6GB DIMM DDR3 Memory Bus Speed : 2x 540MHz (1GHz) Memory Module(s) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Video System Video Adapter : NVIDIA GeForce GTS 250 (128 SM4.0 1.65GHz, 1GB DDR3 2x1GHz, PCIe 2.00 x16) Graphics Processor Adapter : NVIDIA GeForce GTS 250 (128SP 16C 1.77GHz, 1GB 2x1GHz) Adapter : NVIDIA GeForce GTS 250 (128SP 16C 1.77GHz, 1GB 2x1GHz) Adapter : NVIDIA GeForce GTS 250 (128SP 1.65GHz, 1005.6MB 2x1GHz) Storage Devices WDC WD1002FAEX-00Z3A0 (1TB, SATA, 3.5", 7200rpm) : 932GB (C:) WDC WD1002FAEX-00Z3A0 (1TB, SATA, 3.5", 7200rpm) : 932GB (F:) WDC WD1600JS-00MHB0 (160GB, USB/SATA300, 3.5", 7200rpm, 8MB Cache) : 149GB (E:) HL-DT-STDVDRAM GH24NS50 (RAID, DVD+-RW, CD-RW) : N/A (D:) Logical Storage Devices System Reserved : 100MB (NTFS) New Volume (F:) : 932GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA, 3.5", 7200rpm) My Book (E:) : 149GB (NTFS) @ WDC WD1600JS-00MHB0 (160GB, USB/SATA300, 3.5", 7200rpm, 8MB Cache) Hard Disk (C:) : 931GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA, 3.5", 7200rpm) 3.5" 1.44MB (A:) : N/A Optical Drive (D:) : N/A @ HL-DT-STDVDRAM GH24NS50 (RAID, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : Giga-Byte HD Audio Controller Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte 88SE91A3 SATA-600 Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 ******************************End Sandra******************************************** *************** i have read all of the initial suggested reading and have still found nothing to help. the windows 7 optimizations did not seem to do anything either. ive been workin on this for over a week before coming to this board to ask my question. i wanted to make sure i wasnt doing something stupid before i came to the experts. ive been making music for quite sometime, with hard disk recorders form early 90s, but recently decided to upgrade when i got to use pt in a studio. so here is my problem: im getting a multitude of blue screen of death errors. bad pool header, system service exception, memory management, and drive irql not less or equal. i dont see the pattern nor have i found similar fixes. usually these happen after i get pro tools 8 installed, and attempt to run...... sometimes before i can get the validation code typed in. everything on my computer seems to be running correctly, based on what ive written in this thread, is there any advice you may offer? yours truly frustrated, Charles |
well those errors can be several things. But usually related to drivers or bad ram.
Step 1: check your ram. Go to Control Panel. Administrative Tools. Double Click Windows Memory Diagnostic. Restart now and check....ect... Let is scan.. Go get coffee. Come back and see what it says. If no errors, then post back. If errors. Start taking out ram and test each stick to narrow it down to the bad one.
Brian Windows 10 Pro 64 Bit Pro Tools 2019 benonistudio.com Youtube Channel - benonistudio Free Eleven Rack Tutorials, Rigs, and more @benonistudio |
Are you sure ALL of your plug-ins are the latest versions and optimized for PT8?
~ tom thomas Formerly hobotom Pro Tools Ultimate 2019.10 HDX HD Omni and 192 I/Os Windows 10 Intel Hexcore i7 All Samsung Pro SSDs Ampex MM1200 2" 24 trk tape Outboard: UREI, Eventide, Lexicon, Yamaha, TC Electronics, Orban, ART, EchoAudio, Dolby, Hughes, API, Neve, Audio Arts, BBE, Aphex, Berringer, MOTU, dbx, Allison, etc. Plug-ins: Too many to talk about. www.metrostudios.com |
8.04 is WAY more strict about plug in versions than anything i've seen in a while. I don't pretend to know why maybe Shan can chime in but I do know that systems that seemed to be fairly stable and that were usable before are not after the update.
Recheck your plugs. ![]() recheck your plugs ![]() recheck your plugs ![]() needless to say dont try to run any bootleg plugs LOL ![]() Happy hunting also check the cas latency of your ram in the bios this version of PT seems to push XP a bit beyond 8.03 and bring out the worst in systems. |
i have also tried windows xp 64 bit, sp2 and i get an error about redundency, but no blue screen of death.
the only plugins i have are the ones that come with pt8. i will do the ram check tonigh. does the hardware i have seem to be ok? |
Well, your My book is only an 8mb cache. though that shouldent yield a blue screen. What exception is listed at the top of the blue screen?
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
I'm not gonna use the usb drive, just the two internal sata.
The errors are different everytime, but that's all of them. |
so my memory test showed no errors,
and i have no idea how to optimize plugins. i assume they are on the install disk, but have no idea how to mess with them if i cant get the software to boot up. |
could it be the onboard fire wire on the motherboard?
its a ti chip set, |
![]() Quote:
Device Manager. Find your IEEE 1394 Host Controller. Right Click on the correct Firewire device. Update Driver. Browse My Computer. Let Me Pick..... And try each of the differant entries.
Blue Screen on startup w/6.7 | sunnywheat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-02-2007 06:09 PM |
Blue screen, then crash on startup | smitnz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-18-2006 03:02 AM |
Blue Screen on Startup up of ProTools 6.4 | villagechurch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-13-2005 01:51 PM |
Blue screen on startup. Need help. | ericgold | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-18-2005 10:22 PM |
Blue Screen of Death at Startup.... Help!!! | JamesV | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 25 | 08-28-2002 06:20 AM |
