Old 08-01-2020, 09:29 AM
Danny Alcazar Danny Alcazar is offline
Default Pro Tools Perpetual -- PC compatibility
Can you tell me if my PC desktop will run Perpetual? Avid's website requirements show an i5 Processor, but I have an i3.
Here are my specs:
Model: Dell XPS 8930
9th Gen Intel Cofe, i3-9100 (4 core, 6MB Cache, up to 4.2GHz with Intel Turbo Boost)
Operating System: Windows 10 Home 64 bit
Memory: 24GB RAM
Many thanks!
Danny
Old 08-01-2020, 09:59 AM
Default Re: Pro Tools Perpetual -- PC compatibility
Really tough to say. It may work, but maybe not very well. The intel i5 is a recommended minimum processor and to run Pro Tools, you need power. The i3 is a "budget" processor. Beyond that, how many hard drives do you have(and how are externals connected)? What do you plan on using as an audio interface? Here are some things to consider:
#1-If you don't mind paying for an iLok, get the free 30 day trial so you can test it out.(many plugin makers also use iLok so it won't be wasted money if PT doesn't work out)
#2-Pro Tools requires an ASIO driver/device to act as the "audio engine". To use the on-board sound card, you may find it tough to make it all work and you'll be much happier with a separate interface(Focusrite and Presonus make good basic boxes that will work well with Pro Tools).
#3-Unless your computer has a solid state drive, you will need at least a second drive for sessions. This "recording" drive needs to be 7200rpm or SSD(5400 rpm drives are too slow). Having the recording drive installed inside the desktop on a SATA connection will give the best performance. If its external, USB 1 or 2 is probably too slow a connection(if you don't have USB3 ports, maybe you could add them with a PCIe card, which are inexpensive).
#4-if you do the trial and it doesn't run well, Cockos Reaper, Presonus Studio One and Cakewalk(from Bandlab) may work better on a "marginal" computer. Reaper and Cakewalk are free to try(not sure about Studio One) and Cakewalk is just plain free
Old 08-01-2020, 10:08 AM
JFreak JFreak is online now
Hi, welcome to the community.
I am fairly sure CPU speed will not restrict you for starters, you will only need more juice when you run more plugins. And because you have 24GB memory, that is covered as well.
But pay attention to what Dave said regarding storage and interface.
Old 08-01-2020, 10:51 AM
Thank you both for your help and time to write the info for me.
I forgot to mention that I have two hard drives:
256GB M.2PCle NVMe SSD (Boot) -- I would run Pro Tools on this
1 TB 7200RPM 3.5"SATA HDD (storage) -- I would store my song sessions on this
I also have an external drive 500MB
Does this improve my situation?
Thanks,
Danny
Old 08-01-2020, 10:53 AM
Yes, if the internal SSD is NVMe then you should be able to run your session on boot drive, then store it to external for long term storage. You have a fairly good change with that gear -- but take a close look at what has been said about interface and ASIO. I myself am a Mac guy and things are pretty simple on that side of the pond. Someone else will be better help on Windows setup.
Old 08-01-2020, 10:54 AM
You do not need a separate slow old HDD for sessions... with a modern a NVMe boot drive you would be better off putting the sessions on that drive... if there is enough space... I would normally want a larger boot drive.
Old 08-01-2020, 11:07 AM
So, store both Pro Tools and my song sessions on the SSD? What should I store on my disc drive (1 TB)?
Thanks again,
Danny
Old 08-01-2020, 11:08 AM
Move finished sessions to external, that 256GB will not take you very far
Old 08-01-2020, 11:09 AM
Sorry, I forgot to mention my audio interface:
I'm using an Audient iD4
Thanks,
Danny
HD10 Perpetual Upgrade to 2020 Ultimate Perpetual WaterRat Licensing & Accounts 7 04-24-2020 06:47 PM
Pro Tools Perpetual Eelmartin Getting Started 2 11-21-2019 12:15 PM
Upgrading from perpetual PT 10/11 lic. to perpetual PT12? Zakazastar Licensing & Accounts 2 05-25-2019 01:01 PM
ilok license manager - Pro Tools HD Plan vs Pro Tools HD Perpetual Bundle simonchase Licensing & Accounts 3 11-30-2017 05:47 AM
Perpetual license - what exactly stays perpetual SixChurchStreet Licensing & Accounts 5 01-02-2016 10:43 AM
