PT 24MIX system bugs (seached found nada)
Hi all, just moved and upgraded my system to 5.1.3, I seem to be having a problem with the 888/24 interface wondering if anyone could help.
The core card tests fine, all the outputs work fine except for 1 and 2, one nothing comes out of it, and two is distorted. The levels seem fine on the display.. any ideas? Also, does anyone here run the MOTU PCI324 card and a Mix system in the same machine? I'm getting clock errors with the MOTU piece when having the MIX card in at the same time. This happens on a G4 dual 1.25 mirror box. Thanks in advance John |
Re: PT 24MIX system bugs (seached found nada)
Open the interface and check whether the connector of the DA-board sits tight.
I had a similar problem some time ago. Peter
http://www.merlinsound.de |
Maybe if you inactivate all but two I/O channels in the PCI324 console you might lower its PCI bandwith needs ? good luck
Mark Haliday France, Rochefort 17300 Mixing & Mastering, Writer, Teacher Pro Tools Ultimate & Carbon M2 Max Studio |
Well I opened up the 888 and re-seated all the cables. Still getting nothing out of channel one and distorted sound out of two. The rest are fine...
Anyone else? Any ideas |
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration | farmfresh | Pro Tools 11 | 21 | 05-01-2014 07:21 PM |
24mix system DAE with logic pro 7 on OS 10.39 | ollywood | Pro Tools TDM Systems (Mac) | 0 | 12-17-2005 02:32 PM |
do/will 6.7 sessions open on a 6.4 24MIX system? | drewcilla | Pro Tools TDM Systems (Mac) | 1 | 11-08-2004 08:18 AM |
Recording light for protools 24mix system? | nicoTAV | Pro Tools TDM Systems (Mac) | 10 | 01-30-2004 01:30 PM |
Plugins with 24mix plus system | Slypolk | General Discussion | 3 | 07-28-1999 12:09 AM |
