Volume adjust?
I have made an volume automation for one track.
How do I keep the automation and adjust the overall volume without having to adjust every volume point? Danne/
danne |
Re: Volume adjust?
In volume view, drop a curser anywhere in the track, hit command A (select all), then use the trimmer tool to move the whole relative volume curve up or down.
dk
http://homepage.mac.com/dkrausz |
Re: Volume adjust?
Hey, thats helpful for me too. I've been wondering the same thing. Thanks.
Re: Volume adjust?
If you are using PT LE version 5.1 or higher, there´s a stock RTAS plugin in your system called TRIM. Insert the TRIM plug in in the desired track and control the overall volume from there...
I hope it helps.
- e.l - ps: btw...sorry for my english. ;-) |
Re: Volume adjust?
Or you can adjust the input or output levels of most plugs, chances are you'll have at least one on there anyway.
Re: Volume adjust?
Great, thanks for all the suggestions!
danne |
Re: Volume adjust?
Buss your volume automated track to an aux track and use it as a master volume. [img]images/icons/smile.gif[/img]
Can't adjust volume of OS X, only the output volume of ER | JustGoWithIt | Eleven Rack | 8 | 09-26-2011 01:32 PM |
Adjust volume across ALL tracks? | Michael P. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-06-2009 03:56 PM |
can't adjust volume on click track | Mat.R | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-18-2007 07:44 PM |
Is it possible to adjust the input volume ? | andots | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-27-2005 06:10 PM |
Can't adjust volume while recording... | Bodhisan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-24-2003 12:01 AM |
