Old 11-15-2002, 08:32 AM
TonyR TonyR is offline
Default Bussing of 1-band or 4-band EQ
I am using the DIGI001 and I am unable to bus the 1-band or 4-band EQ and hear the difference. i am able to insert it. I am used to using the VS-880 and this had the capability, yet with ProTools I am completely stumped.
Old 11-15-2002, 11:08 AM
Chris Scott Chris Scott is offline
Default Re: Bussing of 1-band or 4-band EQ
Are you soloing the track you are using the Buss on..cause if you are you have to solo the Aux track also....Chris Hope this helps
Old 11-15-2002, 11:13 AM
no i am not soloing either, i am trying to bus a mono audio track to a mono aux track with the 1-band EQ on the aux track. i am able to bus using any other effect (reverb, delay, compressors) but not EQs.
Old 11-15-2002, 12:32 PM
Somethins wrong then..Everything else works except the EQs...Somethin is not right..I've been working on Drum tracks and I have busses with both EQs on and they work great...You might want to call Digi...
Old 11-15-2002, 02:02 PM
Bastiaan Bastiaan is offline
Insert the RTAS-plugin. Dial in some crazy setting to be able to tell the difference. Then you can compare by clicking on the bypass button in the plugin-window. If you use Waves-plugins, you can even make an A and a B setting, and A/B them...
What's that?
- That's the machine that goes "pling".
Bastiaan
.band to PT frcjt macOS 3 05-19-2013 08:48 AM
3-band EQ Steven Massey Pro Tools TDM Systems (Mac) 23 03-21-2006 02:25 PM
6 band EQ? Matt Whritenour 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-17-2003 11:56 AM
OT - YOUR best band name(s) graveleye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 39 01-20-2003 01:18 AM
One band EQ? sonoma bass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-05-2002 10:08 AM
