Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 07-03-2019, 07:28 AM
Mark Ziebarth Mark Ziebarth is offline
Default Import Session Data - how to change the reel?
Hi colleagues,
what is the easiest workaround to import substitute audio files into a mix?
I‘m getting live shows with about 110 tracks each. I‘ve already mixed a show in one session and want to import the audio files from a recent show into my mix. It’s tedious work for me the way I do it now, track by track, by track...
Isn’t there anything like „changing the reels“ in the old days? So you put new audio on all tracks in one go?
Best
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac Pro 2008, RME Fireface, Pro Tools 12, Euphonix MC Control
Old 07-03-2019, 09:17 AM
Default Re: Import Session Data - how to change the reel?
If your track naming is reasonably consistent then it's quite easy; "Import Session Data", "Match Tracks", select the parameters you want to import (in this case only clips, perhaps alternate playlists, clip gain), check for "link to existing audio" assuming that's what you want, and go.
Your sig says PT12 - IIRC, the import parameter matrix checkboxes and presets didn't get added until sometime in PT2018 (and was one of the many excellent additions), so you'll have to go through the parameter list as a submenu of check-offs, which can be slightly painful, but once it's done it won't change until the next reboot. Regardless, it shouldn't take more than a few minutes for each "reel change". I probably do this 4 or 5 times a day...
Is there some reason this isn't working for you?
best,
rich
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 07-03-2019, 10:47 AM
dwaynedelario dwaynedelario is offline
Rich is right. Match tracks is the way to go. Save your mix session as a template. Close. Import the audio files into a new session as tracks, save and close. Open the mix template, import the tracks from your newly created session and "match tracks" on the import dialog. You might have to manually match if the naming from your template isn't the same.
Like Rich said, don't import all session data. Just take clips (main playlist) and clip gain.
HDX2 / OS X 10.12.6 / Mac Pro 2012 40GB RAM
ProTools Ultimate 2019.6
Avid OMNI+Artist Mix
Old 07-03-2019, 09:17 PM
Thanks for your tips, they will help me a lot. My main problem is I don’t get Pro Tools sessions but Reaper projects. If I understand you right I need to create a session with the new show audio first and then import those session data via „Match Tracks“ into my mix template. If I define to import main playlists only the effect will be like changing the reel in an analogue setup, right? I‘ve never used „Match Tracks“ so far but am familiar with the rest of the Import Session Data window. I hope I‘m on track so far.
Does my media management concept make sense? It’s the following: Each show is about 150 GB and I don’t want to copy those files physically while saving the new mix session from the template. So I go with „Link to Source Media“. I will have six to eight shows with the same 22 songs and will need to choose which version of each song will be mixed. After this decision my idea is to create separate sessions for each song including cut down media to be able to mix the songs on separate PT rigs even on my mobile system with limited storage. Another advantage: No song will have 100+ tracks as there are alternate mics for some musicians and singers. Am I missing something?
Best
Mark
Pro Tools 9 crashes every time I open a new session or import session data Ryan Butler macOS 14 03-23-2014 08:53 AM
Import Session Data with out Audio import disinfor Pro Tools M-Powered (Mac) 7 11-14-2010 12:44 PM
import session data without audio data rgalpin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-06-2010 02:49 PM
End of Stream Reached - session broken - import session data does not work... Sean Russell Pro Tools TDM Systems (Mac) 0 01-15-2010 05:56 PM
Import track color in import session data deardaddy Pro Tools TDM Systems (Mac) 5 06-11-2007 07:35 PM
