How to Join & Post  ē  Community Terms of Use  ē  Help Us Help You
Knowledge Base Search  ē  Community Search  ē  Learn & Support
Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 07-18-2018, 01:57 PM
Tom Case Tom Case is offline
Default Adjust every edit at the same time
Hello, I have chopped up my drums, grid aligned them, and used beat detective to fill in the blanks and fades. I find if I slide the edit to slightly before the drum hit, it sounds better.
Is there a way to move every edit, say 100ms forward, all at once?
Thanks.
Old 07-18-2018, 03:24 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Adjust every edit at the same time
Highlight all the clips you want to move, change the nudge value to 100 ms, hit the minus key (-) on the number keypad. Everything highlighted will move 100 ms to the left. If you want them to go to the right, hit the plus (+) key on the number keypad.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 07-18-2018, 08:13 PM
The clips are exactly where I want them, what I want to do is use the trim tool to move the "splice" between each clip forward 100ms. All at once. This would be a monumental time saver for me.
Thank you so much.
Old 07-19-2018, 12:05 AM
Dizzi45Z Dizzi45Z is offline
I don't know of a way to do exactly what you want to do. But I know an easy work around that will get you the exact same result.
Set the nudge value you want to move the edits by.
Then select all the audio you want to adjust the edits on and press "cntrl -" The minus must be the minus key on the numeric keypad. You will see the audio all shift to the left by your nudge amount while maintaining the edits exactly where they are.
Next, press the same minus key again and it will shift all of the audio back to the position it was, but the edit will move to the left and will result being early by whatever you had set the nudge amount to.
Hope that makes sense and does it for you.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools 12.8.3 HDX Mac OS 10.12.6
Mac Pro Quad 3.2 Nehalem with 32 GB RAM
Noisebox Studios -Utah Recording Studio
Old 07-19-2018, 01:09 AM
midnightrambler midnightrambler is offline
This is an excellent trick.
Old 07-19-2018, 10:30 AM
priorytools priorytools is offline
Thanks.
Yes, having the edits before the hits is better. . The trick is, when you use BDetective, to set the trigger pad time to 10 or 20 ms. . this then cuts the beats that far in front of each beat & places a sync point on the beat. .
You could either redo all you slicing etc with that in mind, or try redoing your fades. . Delete all your cross fades, then select all the regions(clips) again, select "fill & crossfade" and enter your 100ms figure there. .
Try that first mate.
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.12.6 / Pro Tools HD 12.8.3 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V3.6 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.6 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.8.3 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
Old 07-19-2018, 03:09 PM
dwaynedelario dwaynedelario is offline
If the splice is in the same location on each track, couldn't you group the tracks and use the trim tool to move the edit point?
HDX2 / OS X 10.12.6 / Mac Pro 2012 40GB RAM
ProTools Ultimate 2019.6
Avid OMNI+Artist Mix
Old 07-19-2018, 03:52 PM
Wow, I canít wait to try this. Thank you so much.
I use tab to transient to slice each hit, then slide them to the grid. Iím only using the fill and cross fade aspect of beat detective, so I canít let it put the space before the hits.
The tracks are grouped, Iím trying to make the same edit adjustment on the entire song.
Thanks so much everyone. I shall report back with my success.
Old 07-20-2018, 04:43 AM
Tab to transient for every hit ? . . Jeez, that must take some time dude . .
Well, I would suggest redoing the xfades as I posted.
Old 07-20-2018, 02:56 PM
OMG. You are my hero, I can't thank you enough. Works great.
I did run into a hiccup, I'm on windows, so "ctrl -" didn't work as described, so I kept hitting different keys plus the minus key, and it's the Windows key plus the minus key for the first move.
Time adjust on MIDI DonaldM Tips & Tricks 5 12-07-2015 11:41 AM
Space plug in,how to adjust T60 time? Rockman413 Pro Tools 12 0 09-29-2015 04:21 AM
How to adjust Track Width in Edit Window larsongs Getting Started 14 06-16-2014 10:14 PM
How to adjust tempo in real-time? ddecker1979 Tips & Tricks 1 09-15-2010 07:28 AM
Fine adjust fader in edit window caput! command+adjust crizdee Pro Tools TDM Systems (Mac) 2 12-09-2008 04:55 PM
