Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 09-25-2001, 01:39 AM
Fucius Fucius is offline
Default Anyone know how to time-stamp audio in logic audio and imort it into Protools?
Anyone know how to time-stamp audio in logic audio and imort it into Protools? I'm thinking of switching to using Protools but I need to import all my LAP sessions into Protools somehow. Any ideas? [img]images/icons/smile.gif[/img]
Old 09-25-2001, 03:53 AM
jackruston jackruston is offline
Default Re: Anyone know how to time-stamp audio in logic audio and imort it into Protools?
I think if you export the logic files as sound designer 2 files, they will be stamped...but I could be wrong. A workaround for this is to insert silence from the start of the session to each audio file, then save as a complete region. When you want them in pt just put them at the start. not ideal I know. I think theres something in the pt manual about the stamping thing.
Jack
Old 09-25-2001, 05:10 AM
Peter Duemmler Peter Duemmler is offline
Open the Audio Window, select all, look for the menu item "export SDII regions", select it, done.
Check in ProTools, as Logic´s export doesn´t seem to be that reliable...
If you get out of range errors check SMPTE offsets.
Good luck,
Peter
http://www.merlinsound.de
Old 10-05-2001, 11:09 PM
abraxas abraxas is offline
In Logic after you export SDII regions, with all the audio still selected, you can then import SDII regions to make sure every region displays a little clock symbol. Then you know all have been exported with the timestamp before closing Logic and opening PT only to find that some files didn't timestamp.
Protools 10(not HD) vs Logic audio Sonically digi003 Pro Tools 10 1 11-12-2013 10:25 AM
keeping time stamp when importing audio files sandyneillevine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-07-2002 02:51 PM
running Logic Audio and Pro Tools at same time deltacon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-26-2001 01:57 AM
ProTools 5.0 and Logic Audio 4.7 DennisClark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-09-2001 12:37 AM
protools LE vs logic audio bz_109 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 04-23-2001 04:56 AM
