No firewire but I wanna go external. Is a USB Hard Drive worth trying? (Windows 7)
I am getting some serious slow down/freeze up issues and after reading up on this site I realized a lot of it is coming from recording on my Laptop's hard drive
I know you guys said Firewire is the preferred external hard drive.. but I don't have that option. I just want to know if there is any point buying a USB 2.0 Hard drive or should I just stick with my onboard and try to find other ways to speed pro tools up? Here are my specs ProTools 8 M-Powered M-Audio Fast Track Ultra 8R HP CQ61-420US Notebook AMD Athlon II Dual-Core M320 @ 2.1 GHz 3 Gigs Ram Windows 7 Home Premium 64 Bit In your general troubleshooting guide I disabled "Desktop Composition" (Which was handy, I was kind of bugged that when I disabled it manually on my own, Protools would just restart it when I ran it :P thanks for the help) |
Re: No firewire but I wanna go external. Is a USB Hard Drive worth trying? (Windows 7
USB drives are actually recommended for Windows 7, while FireWire drives are not.
A better option would be to get a second internal SATA drive. |
Thanks man that helps me a lot :)
any specs on the drive that i should consider when buying? or would be ok to pick up a cheaper one |
DigiTech, What issues can one expect to encounter when using firewire external hard drives and a laptop, since that is my setup at this time? Also, what usb slot card is supported by ProTools...
No Firewire, but I NEED to go external. I'm quickly running out of HD space. I have a USB 7200 RPM 1.5 TB Glyph drive arriving Monday where my sample libraries are going have to go. I have Komplete 7 arriving as well. I have 85 GB free space on my system drive and I need 90 GB just for Komplete. The engines will go on the system drive, but I need to put my samples on the Glyph.
For M-Powered PT 8.0.4 cs2 will this cause any issues? Windows XP SP3. And due to a lot of stuff on the main USB bus, I've got an "I/O Future" High Speed PCI USB 2.0 host controller. 5 port. PU520 Basic sys info in signature.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) |
I really don't recommend it. Generally speaking and brand name USB card will work. We don't test them specifically, but I haven't heard of any rampant problems with a particular brand. |
I've been using Maxtor, works great.
Pro Tools 12.6.1 for Windows 10 ASUS Core i7 3770 Yamaha Steinberg UR 44 Golden Age Project Pre-73 JR Warm Audio WA12 MKII Preamp Glyph 1TB GPT50 external drive - Firewire LaCie 1TB external drive - USB JBL LSR305 monitors AT 2020 & 2021 Equation F.20 condenser mic |
Thanks for the advice all...... I've had a couple session expierience the delay to recording after hitting the REC key, and wondered about maybe just inadvertantly clicking on something to cause that problem.. Now I know what was happening... Have gone USB for the external drives... Thanks again
External firewire hard drive | mtbass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-09-2008 01:15 AM |
Using an External Firewire Hard drive | Leon B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-02-2004 03:43 PM |
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be | Fucius | General Discussion | 4 | 03-19-2002 11:26 PM |
External Firewire Hard Drive.....how about this one...... | jason66213 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 10-31-2001 12:05 AM |
firewire/external hard drive | guys | Storage Subsystems | 0 | 04-25-2001 11:33 AM |
