Old 05-08-2011, 10:55 AM
jem777 jem777 is offline
Default Automation Error or problem with Control Surfaces
I have a strange problem in PT HD 9.0.2 on Mac with Command 8.
I was mixing a track for the third time, to make some adjustments. the two runs before went ok, then i had this problem.
I have a vocal audio track and an Aux-track. On the Aux-Track i use Doubler to make the voice bigger in the chorus. So i have done Mute-Automation on the Aux track to only play in Chorus, and i have volume automation on the Vocal track. Suddenly at the third run i have noticed that i had no sound from the Aux-track, but the meter showed signal flowing through the track. When i just touched the fader on this Aux track, the audio was audible again instantly, but then after a few seconds died again. This could be reproduced repeatedly. Id did not matter if i touched the fader on the Command 8 or klick on it with the mouse. I could not get it to work again, i even restarted PT without success. I helped myself by finally writing Volume automation to the Aux-track itself by simply touching the faders in chorus and let go in between (well, in between it was muted anyway) Then i did not get this behaviour again.
I had this once in the past if i remember correctly. I had just bought the MC Control from Euphonics and had some other issues as well, so i thougth the problem lies with the MC Control and maybe Eucon (wrong guess as it turned out). Now i have a Command 8.
Does anyone else experienced this, too ? Really scary that a track is not played like it should, makes me a little concerned about reliability of PT. Of course usually someone hears if a track is not played, but i don't really want to check for that all the time and concentrate on other things in the mix.
Regards
Bertrand
8.0.3, some control surfaces cause 6031 error kinghand Pro Tools TDM Systems (Win) 7 12-22-2009 05:44 PM
Control Surfaces for PT LE adam79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 21 04-02-2007 07:43 AM
Control Surfaces Dabbler Pro Tools TDM Systems (Mac) 2 04-01-2006 11:05 PM
Other control surfaces? Red Alert Pro Tools TDM Systems (Mac) 1 09-09-2003 03:11 AM
Control Surfaces? siko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-19-2002 08:29 AM
