Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 05-23-2001, 12:08 PM
SOR SOR is offline
Default Audio Files Gone, including Backups.... HELP !!!
did a weeks worth of vocal Tracks, and now there GONE .. nowhere to be found
in my HD's
i ran Norton Utilities (Unerase) and still can't find them...
whats really strange is there also gone from the Backup ..
Can Anyone Help ?
Thanx
Adam
StudioOne Recording
adam@studioonerecording.com
Old 05-23-2001, 03:06 PM
tal herzberg tal herzberg is offline
Default Re: Audio Files Gone, including Backups.... HELP !!!
What backup device were you using???
Old 05-23-2001, 03:19 PM
SOR SOR is offline
i'am using Another hot swap Hard Drive ...
Thanx
Adam
Old 05-24-2001, 11:32 AM
molokoplus molokoplus is offline
Do the vocal files show up when you look in the associated session or backup's Audio folder? If they do, maybe your session is corrupt. Try importing the vocal files into the session or start from a fresh session and import everything you need.. You might end up needing to move a few things around for timing's sake, but at least your week's worth of work isn't lost (I hope) . Hopefully I'm not insulting your sensibilities ... good luck.
Old 05-24-2001, 11:37 AM
Just thought of something else ... what was your disk allocation set to for those vocal tracks? Could they have mistakenly been allocated to a different drive? This would also explain the backups not having the files either. (if you simply drag copied the whole drive) Also, if you remove some hotswap drives without unmounting them, then reinserting them, you can destroy the drives catalog data, thus 'losing' files. Again, hope I'm not telling you something you already know.
cheers
Old 05-24-2001, 03:35 PM
<<<i'am using Another hot swap Hard Drive ...>>>
This is not considered backing up!!!
Use only tape (DDS or AIT etc) or DVD RAM or CDR to back up your work!!!
Old 05-25-2001, 01:39 AM
stevegalante stevegalante is offline
Tried with MacMedic ?
www.downinhollywood.com
http://www.stevegalante.com
System details :
ProTools Native card, Ultimate 2019.5, MacPro 5,1 12 Core 3.33GHz, 64Gb RAM, Mojave 10.14.4, Lynx Aurora(n), Raven MTi
Old 05-30-2001, 09:57 AM
Mano Mano is offline
Just in case you are not aware of this:
Unerase doesn't work at its best if you don't have the filesaver extension installed and working on your system drive. This particular extension actualises your drives everytime you start up and/or shutdown your system and keeps track of everything that is moved , deleted, initialized and other so called horrors On the other hand the filesaver extension is a kind of Pain in the A... together with PT( so I'm told. )
Old 05-30-2001, 12:50 PM
Doug Ring Doug Ring is offline
Have you tried looking on your startup disk? It's amazing where files can end up. Someone said check disc allocation under the setups menu. Doesn't that give you any clues?
Midi notes completely disappearing ... including all backups! meech Pro Tools TDM Systems (Mac) 10 02-17-2010 02:17 PM
Lost audio files and weird auto backups... corrupt session? doubtful guest Pro Tools TDM Systems (Mac) 3 12-11-2009 02:52 PM
Spikes in files from backups Mark Wheaton Pro Tools TDM Systems (Mac) 4 01-16-2003 03:26 PM
Making CD Backups of Pro Tools files madkin Tips & Tricks 4 07-08-2001 07:21 PM
Audio Files Gone, including Backups.... HELP !!! SOR Pro Tools TDM Systems (Mac) 1 05-23-2001 07:20 PM
