Old 06-18-2010, 11:15 PM
simpke's Avatar
simpke simpke is offline
Default Midi Piano Sustain Disappearing
Hey Everybody,
Protools is doing some things with midi that I cant figure out.
I am recording midi on a stereo instrument track using my keyboard.
I have a sustain peddle attached to the keyboard and I'm using it through out
the whole piece. Everything sounds good and plays back fine until I try to trim up the recorded midi at beginning and end where there is no data. When ever I try do this my piano sustain on the recording disappears. Whatup wit dat?
Old 06-19-2010, 08:17 AM
Dorian Green Dorian Green is offline
Default Re: Midi Piano Sustain Disappearing
It happens often because of some RAM overload!
Don't worry, it's only a process issue, the instrument samples don't fully load.
So...
Save your instrument settings, remove it then Reload it!
It often fixes this issue.
It happens often to me using MiniGrand.
I hope it will work for you.
Gd luck.
Green Room Studios, France
Mac Book Pro i7 15"4 Mac OSX 10.6.6
PT 9.0.2
DIY Intel Core 2 Quad, P5B Premium,DDR2 6GB, Win 7 Ultimate.
PTLE 8.0.4
002R Unit and MBox Mini
SSL XLogic Alpha Channel.
SPL Goldmike valve Preamp.
DBX Analog Compressors, Gate and Eq.
Monster Cables
Home made & Neutrik Patchbay.
Brauner, Shure, Seinnheiser and T.Bone mikes.
Tannoy 8D Active monitors.
Old 06-19-2010, 03:50 PM
ryanwilsonfive ryanwilsonfive is offline
I'm not sure if that's what simpke is asking. I too have this problem with midi data on an instrument track, using my keyboard controller and sustain pedal - punch recording, editing, etc. It could be any type of plug-in (piano, organ, synth, etc.), it's just the way it's writing the midi information. Afterward, I have to go in and fix the sustain, pitchwheel, etc., automation info manually. Is there a way around this? The real problem is when punch recording a keyboard part and the sustain is stuck in either poisition. I usually end up using multiple playlists to record, then manual editing later.
http://ryanwilsonfive.com
Old 01-06-2012, 04:19 AM
silverspoon silverspoon is offline
Default peddle
So...
Gd luck.
Hi,I am just starting out.Have a Midi piano,M-audio,protools se.
Can I use the sustain peddles on my piano or do I need to have a seperate peddle that connects up elsewhere? Thanks for the advice above,I'll take note of that for the future..
More effective editing of Notes and Sustain on a Piano (MIDI) track Stig Eliassen Tips & Tricks 4 08-05-2013 08:35 AM
MIDI Record Piano no sustain pedal MarkWorsnop Pro Tools 10 1 06-17-2013 09:58 AM
Serious problem! piano sustain pedal controls tap tempo through midi! gvees Eleven Rack 1 07-28-2012 04:54 PM
Problem with recording MIDI piano sustain pedal Chris7514 MIDI 5 06-11-2008 01:56 AM
Piano sustain pedal in recording Help!! Zownd Tips & Tricks 9 04-05-2004 03:21 PM
