Old 09-21-2005, 10:06 AM
crizdee's Avatar
crizdee crizdee is offline
Default control 24 faders jumping around
Faders on my c24 are jumimg around! sometimes up to 8-10 in a row will suddenly fly down and then to the top and also some of the EQ DYN INSERTS lights go on and off. it has happened on several sessions. i have tried re boot of all, but it has happened again since.
I hear about the power supply failing on these a lot! is this the usuall sign? i'll be surprised as this has only had 3-4 months of proper use! most of its time was spend boxed at another studio not being used. unfortunately this is out of warranty!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-21-2005, 11:19 AM
player player is offline
Default Re: control 24 faders jumping around
soundz like the problem I had until we put in a new power suply. happens to most c24 owners (I heard....)
take care
www.soundmill.dk
Old 09-21-2005, 11:30 AM
tonicjeff tonicjeff is offline
Sounds like the start of the PS problem..
Intel Nehalem 8 Core 2.26 w/10 gigs of Ram
4 internal sata drives (1 terabyte)
Magma Pci to PCIe 6 slot chassis
PT 8cs3
HD 2 Accel
1 Process Card
UAD quad
PT 8.0.1 cs 1
OSX 10.5.8
Ctrl 24
Old 09-21-2005, 11:59 AM
crizdee's Avatar
Well, it also started to omit spikes in the monitors, so i have taken it apart to try the old clean the connectors routine and hope for the best!
Failing the cleaning of contacts then i guess its a replacement PSU! is it just a simple replacement of the whole power board on the back? i'm hoping Digi can send me the PSU and i connect it all myself!! any experience on this? can't afford to be closed for return to factory!!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-21-2005, 03:38 PM
crizdee's Avatar
Just to update, i took the power supply out and cleaned every connector with a cotton bud and switch cleaner lubricant! all 10, and put it all back together and it has worked ok for 2 hours with no problems! hopefully thats the fix, but won't know fully till tomorrow when i'll be working 10-12 hours.
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-21-2005, 04:02 PM
PlanB PlanB is offline
Crizdee,
I have seen this happening to almost all C24 units I installed for customers. It is indeed a PSU prob and a well known issue.
Time to ask for an RMA...
Hope this helps
Cheers
Arthur
Old 09-21-2005, 04:54 PM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
Crizdee,
Hope this helps
Cheers
Arthur
I second that ... get it ordered now and swap it out - it will fail sooner or later. Assuming you haven't ever changed it out - if you have the latest revision then perhaps the clean is all you can do .. they'll help you identify it on the phone ..Ainslie
Ainslie
http://www.ainsliegrosser.com/
MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio
Old 09-22-2005, 01:55 AM
crizdee's Avatar
Thanks for the words of wisdom guys, it did work fine last night for 2+ hours! but i guess a full day of use today will tell if cleaning the contacts was thr fix or not. It previosly worked fine yesterday till 4-5 hours into the session and the heat had built up a bit! and thats when it started, maybe heat related!?
I think you are all right and i better order a spare PSU now.
Regards
Chris
Producer, Engineer,
www.ukmastering.com
Control 24 faders jumping/not working fix!! crizdee ICON & C|24 2 08-22-2021 09:50 AM
control plugin parameters and sends with faders on MC Control jacko Artist Series 1 01-03-2011 03:12 AM
Jumping Faders??? bcs723 VENUE Live Sound Systems 4 05-06-2009 12:01 PM
003 faders sticking/jumping back to 0 steve mezclador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-15-2008 11:27 AM
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... domsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2004 07:06 PM
