Record Clips Starting at a take number other then 01?
H,
I know PT Names the record Files of what ever the Track is named and adds sequential numbers at the end 01, 02 , etc What I want to do , is to be able to start the sequential numbering at another number, such as 200,201 . etc . It doesn't seem to matter if you rename clips and or files on disk. PT picks up counting from the last take... Thoughts? Thanks! |
Re: Record Clips Starting at a take number other then 01?
Just name your first Playlist as "Audio.200" and let PT count up from there
Thats not what I need. If you name Track XXXX_200 all following takes will be named . XXX_200_01, XXX_200_02. What I need is XXX_200, XXX_201.etc Thx |
Why not just Batch Rename the Clips?
What Albee said is correct. Don't rename the track, but the playlist. i.e. name your track, create a new playlist first and change the number in the popup window to whatever you want the first take to be. If you already have playlists, create a new one and rename it and it will count up from there.
---------------------------------------------------- MacOS 12.4 / Pro Tools Ultimate 2022.4 |
The work flow does not/can't use playlists, this is for VO Dialog record work where a client wants to start from take ...ex xxx_200..xxx201..xxx202, Takes are recorded sequentially/linear on one track. Renaming afterwards doesn't solve the the issue. Thx! |
HI,
Ah yes! Thx I created a new track, then new playlist changed to 200. This does what I was looking for!!! Thx so much!! Best! |
Ugh, I jumped the gun... Clips still don't count they way Im looking for,
Play list only takes on new name, ex ...xxx.900, clips count xxx.900_01, xxx.900_02 as opposed xxx_901,xxx_902 Thx |
Let's say you have a track called ADR1. If you create a new playlist, and change the name of that playlist in the pop-up window from "ADR1.01" to "ADR1.900," you should get your first clip named "ADR1.900_01" and when you create the next playlist for the next take, it will be named "ADR1.901_02."
You are creating a new playlist every time you record, correct?
Here is a screenshot of what it should look like following this procedure.
Does number of clips effect the speed of a session? | ianbee | Pro Tools 10 | 4 | 09-14-2013 05:51 PM |
Naming of clips when audio file ends with a number | John Link | macOS | 5 | 06-02-2013 04:36 PM |
Help-delay when starting record | Jeff ONeil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-14-2010 01:24 PM |
Lag when starting record | WeNdeL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-23-2006 09:45 AM |
OT......Starting a Record Label | Punx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-17-2003 06:06 AM |
