  #41
Old 06-02-2018, 08:30 AM
dankin dankin is offline
Default Re: „AAE -9173 error“ - the biggest pro tools workflow killer over the last years
Originally Posted by dwaynedelario View Post
I don't normally buy into the hype on these types of solutions, but I was losing my mind with -9173 on a session with 35% usage. Did all the optimization routines and nothing helped until I used TURBO BOOST SWITCHER! I have 7 inserts on my master aux as well (PA, Waves, Slate, Izotope etc).
Same here. It's made a huge difference on my MBP. For me once I would get above 40% or so, it was constant -9173's. It's the only thing that has helped at all. I've actually been mixing a project the last week that's hitting the 256 voice limit. CPU hitting 80-85% range. I've seen a couple -9173's, generally only when instantiating a plugin while playing back ,or forgetting to close Safari.
Chaining multiple aux instead of one, can have an affect on core usage. Since one channel can't share cores, it helps spread the load more evenly. In my experience it depends on what plugs you are using in the chain as to how much it helps. If you have 2 or more CPU heavy plugs in a chain, it can help for sure IME. On the other hand, if the plugs in the chain are light on CPU, it may not make much of a difference, if any.
2018.3 HD, MacPro 5.1 12core 3.46, 24gig ram, OS 10.12.6, 2014 MPB 2.8, OS 10.12.6
  #42
Old 06-02-2018, 08:47 AM
dwaynedelario dwaynedelario is offline
Originally Posted by Franklyn View Post
Hey dwaynedelario,
1.
do you have most of waves plug ins?
so I can upload a little test session (without audiofiles). and i am sure you have the same problems with it :)
in the session are the following waves plug ins:
Sheps 73
Kramer Pie
H-EQ
NLS
H-Delay
H-Reverb
Kramer Tape
Abbey Road Vinyl
DPR-402
CODEX
sheps parallel particles
Greg Wels Mix Centric
Maserati GRP
ProLimiter (Avid)
hey Franklyn. Yes I own mercury. Feel free to post the session and I’ll try it out. Will 9173s occur if no audio is being processed?
HDX2 / OS X 10.12.6 / Mac Pro 2012 40GB RAM
ProTools Ultimate 2019.6
Avid OMNI+Artist Mix
  #43
Old 06-02-2018, 08:50 AM
Hey dwaynedelario,
1.
Sheps 73
Kramer Pie
H-EQ
NLS
H-Delay
H-Reverb
Kramer Tape
Abbey Road Vinyl
DPR-402
CODEX
Maserati GRP
ProLimiter (Avid)
Also looking at your list, I can tell you that Codex causes massive headaches on my rig. I have to freeze it, even in light sessions.
  #44
Old 06-03-2018, 08:38 AM
Ru_C Ru_C is offline
I'm not sure how relevant this is to others issues, but i've become convinced the poor low latency performance on PT NON-DSP is connected to how PT handles the graphics, rather than the audio.
This is a quick demo video I've just made.
https://youtu.be/syhrOtDpaWg
Its a typical rock/metal session i'm working on at the moment . 60 tracks of audio, 16 strereo auxes for bussing & FX, & bunch of plugins.
Waves, Sonnox & AVID plugins used liberally throughout.
I've armed a pair of tracks & am attempting to overdub with a 32sample buffer.
With the Edit view running as normal in the background, we get the CPU spikes many of us have become familiar with.
Switch off the Edit view (PT still recording in the background) & the CPU usage massively drops off. Switch Edit view back on & they return.
Obviously working in the dark without the Edit view on is not very practical, but this does possibly point to where AVID could be making code optimisations .
Just my 2 cents/pence worth.
Studio A: Mac Pro 12 core, OSX 10.9.5, PT HD 10.3.10, HD3 Accel, AVID I/O 16xanalog i/o x2 , Benchmark DAC1, 32 Fader Procontrol
Studio B: Mac Pro Dual 8 core, OSX 10.8.5, PT 10.3.10, HD3 Accel , 192-Digitalx2, Apogee+Audient/Converters
Home: Mac Pro Dual 8 core, OSX 10.9.5, PT 10.3.10, HD3 Accel. 96 i/o (Dual boot with) OSX 10.13.6, PT 2018.x.x, Focusrite Scarlett 2i2
Mobile: 2017 Macbook Pro, OSX 10.13.6, PT 2018.x.x, Focusrite Scarlett 2i2
  #45
Old 06-03-2018, 09:30 AM
jchan jchan is offline
I mean:
"Initial testing of Pro Tools with macOS 10.13.4 has shown serious problems with CPU performance.
Avid is working to find a resolution for this.
It is recommended that users refrain from updating to 10.13.4 until further notice."
I have the same experience as Franklin.. Bombarded with 9173. Restarting PT helps for some time.
Izotope RX here..
Franklyn : could it be when the plug-in delay on a channel is bigger than ADC can handle? = 16384 samples..
RX often exceeds the maximum delay PT can handle looking at the channel DLY info..
  #46
Old 06-08-2018, 10:50 AM
Olsoda Olsoda is offline
Can confirm I experience similar phenomena. Hiding Edit/Mix seems to prevent wild CPU. Same with integrated or dedicated graphics card installed. Checking or unchecking “Enable GPU” in PT preferences makes no difference.
-9173 Error Pro Tools 12.6 PowerofEight Pro Tools 12 5 09-13-2016 09:01 PM
Pro Tools AAE-9173 Error with Antelope Zen Studio Dusan Tips & Tricks 1 06-28-2016 05:09 AM
Pro Tools 11.1.0 AAE-9173 Error justus1900 Pro Tools 11 4 12-22-2015 03:46 PM
Pro Tools ran out of CPU power - Error Code AAE-9173 dewmi Pro Tools 12 1 10-24-2015 11:58 PM
Pro Tools 11.3.1 Error Codes -9171 -9172 -9173 -9129 -9093 priyatsomo Pro Tools HDX & HD Native Systems (Mac) 11 02-27-2015 07:23 AM
