  #31
Old 02-12-2015, 02:34 PM
Default Re: Has Pro Tools 11.3.1 helped?
Originally Posted by thanos4 View Post
thanx for trying it out...
pretty sure that's avid fault...same system same plugs (all updated to last version)...
They did "something" from 11.2.2 and later which causes the crashes...
11.2.1 is sooooooo rock solid!!!!!even in my yosemite 10.10.2 test drive...
thank again
Can't see how you can say this is Avid's fault because if it was a LOT more people would be having issues.
As an addendum - I tried the same thing in the OSX 10.8.5 partition and the OSX 10.10.1 partitions and no crashes. Interesting thing I noticed is that when run in the OSX 10.8.5 partition cpu usage was down on an average 5 percentage points (meaning it ram from 7% to about 20% cpu usage as shown in PT11.3.1) from the OSX 10.9.5 partition test and ram usage was down 6 percentage points as well (14% ram usage versus 20% ram usage in OSX 10.9.5). When ruin in the OSX 10.10.1 partition I got the same usage specs as the OSX 10.9.5 test.
  #32
Old 02-12-2015, 04:56 PM
thanos4 thanos4 is offline
Ok….see this image:
I PAY…. and i paid from version 7..so i am not a new boy in town and i know what is happening…
Everything works from day 1 (regading version 11) ….from version 1 till 11.2.1 ….sooooo ????after all these years and experience,i tell you it's their fault….end!!!!
So simple…..
Here….we try to find solutions for us users…
don't be so cruel…this is for us….
other users have other problems….this does not mean that they are dong something wrong…..but imagine that you have an application that is is supposed to be working in a thousands pcs and macs with thousands of variations regarding hardware etc etc….
And once more…here in this forum…we try to help each other ….
  #33
Old 02-12-2015, 06:03 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Did you tried loading them in 11.2.1?
I think if they were corrupted probably they wouldn't load...download the dmg again...
I was going to test 11.3.1 tonight clean install and see if I can reproduce. May try downloading the DMG again if it keeps happening. I think I started my tests on ML with 11.2.1 which ran solid, which npromptted me to try yosemeti. I'll keep plugging away, no projects right now, so this takes it's place.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
  #34
Old 02-12-2015, 06:42 PM
Ok….see this image:
So simple…..
I am trying to help when I say it doesn't happen to me and a lot of others; just a scant few have crashing issues when looping. If others had it I'm sure Avid would have jumped on a fix yesterday. Experience/length of time using PT doesn't enter into it. Having a clean supported system helps with a lot of issues and those that run outside of that can expect to have troubles others don't have.
Maybe if Avid had a locked-in hardware (computer/software/interface) system like a Playstation or XBox there wouldn't be these issues. When a myriad of possible systems exist - expect problems. Avid can't possibly test on every possible hardware combo out there.
  #35
Old 02-12-2015, 08:53 PM
Rajsmoove Rajsmoove is offline
11.3.1 has been running great for me over the last 2 days. Haven't had any errors and running at a 32 buffer on my HDN system on a 5,1 6core MP. Even recorded some extra harmonies with a full mix going. Haven't seen any crazy spiking so I'm happy so far
  #36
Old 02-13-2015, 11:26 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Excellent. Good news. At least 11.3.1 does not seem to be worse.
Yes, please let us know the results of your future tests,
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
  #37
Old 02-14-2015, 06:17 AM
hooksound hooksound is offline
No, 11.3.1 didn't help much here. Must say that there are still many annoying bugs in PT11. It is especially frustrating, that one has to remix old sessions because of odd behavior in PT11.
PT10 is at your service and that's fine, but one does not gain much from the highly acclaimed new features in PT11 by having to revert to the old version all the time.
Pro Tools 10.3.10, Cubase Artist 7.5.40, Allen & Heath Qu-16, Focusrite Scarlett 18i8 2G, Fujitsu Lifebook AH532, Intel Core i7-3612QM, 8 GB RAM, Windows 7 Professional SP1 64 bit
  #38
Old 02-25-2015, 04:44 AM
holler holler is offline
This is probably old news but, I un-ticked "Video Engine" "Enable" and my CPU-usage went from 95% to 30-40%. I've never tried it before, but it seems to help a lot
br
EDIT: we can probably scratch that, seems to have been temporary, but feels like it helps a little
  #39
Old 03-02-2015, 03:34 PM
s0nguy s0nguy is offline
this is now happening to me as well.
I did two days worth of systematic troubleshooting and it turns out Stylus was causing the crash... I emailed Spectrasonics and they said that Digi is aware of a crash 7 minutes into a session and it isn't only Spectrasonics plugins... big help.
It crashes only when Stylus is on my session. I have even downgraded from 11.3 to 11.2
anyone have ideas?
retina iMac 3.5 i5
16gb
PT 11.2.2
osx 10.10
  #40
Old 03-02-2015, 04:27 PM
anyone have ideas?
retina iMac 3.5 i5
16gb
PT 11.2.2
osx 10.10
only solution for now is to go back to 11.2.1 (everything works with this version)
You guys helped once, please help again: swirling noise 11R Newbie Eleven Rack 22 06-24-2012 05:42 PM
Thank you to all who have helped today.... stevegrisham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-15-2004 03:02 PM
HELPED NEEDED PLEASE CHRS Tips & Tricks 3 10-30-2003 08:37 PM
How can you penalize who helped you grow? MAXIMUSIC Pro Tools TDM Systems (Mac) 33 09-17-2003 08:05 AM
To all who have helped: thanks & hallelujah!! athlone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-11-2002 10:48 AM
