Old 06-28-2008, 03:35 PM
Jose Alva Jose Alva is offline
Default LE 7.3.1/Error -6085
Hi everyone:
A few days ago I installed an MBox 2Pro/LE 7.3.1, and started playing around (I was working for a long time with Pro Tools 24/Mix Plus) with no major problems. Yesterday I installed Digital Performer (DP 4.12), 'cause I like to sequence on it. I don't know if it was a coincidence, but now when I hit play in PT, an Error -6085 notice appears. I've tried with different H/B Buffer sizes, as well as different sessions, but no way, PT doesn't run. (I didn't find that error in a list of troubleshooting of Digidesign). (I didn't launch Digital performer while I was in Pro Tools).
One more question. With Pro Tools Mix/24, there was a DAE folder in the Mac hard drive. Now, with PT LE, I didn't find any DAE folder. Does LE works with another type of audio engine?
Thanks in advance for any help!
2.3 GHz dual Mac G5
2 GB RAM
OS X 10.4.11
MBox 2 Pro
Pro Tools LE 7.3.1
DP 4.12
Old 06-28-2008, 05:32 PM
Phil Ogden Phil Ogden is offline
Default Re: LE 7.3.1/Error -6085
I think you'll need to upgrade DP to at least 4.6 to work on Tiger. I run a similar set-up (dual 2.0 G5/OS10.4.11/PT7.3.1cs6/Mbox2/002/DP5.0).
If that doesn't solve your problem, then consult the troubleshooting thread (above) for information about disabling any background tasks (e.g processor cycling/Airport/Bluetooth/ FW Networking) that might be kicking-in and causing the -6085 errors.
Re PT LE, I don't recall seeing a folder specifically titled DAE on my HD.
http://www.myspace.com/philogg
Old 06-29-2008, 11:10 AM
The Night Train The Night Train is offline
You will want this update: "Pro Tools LE 7.3.1cs6"
Fixed: Upon First Playback, DAE -6085 Error With Mbox 2 Pro on Mac OS X (Item #83789)
* The workaround was to unplug/replug the Mbox 2 Pro after booting the computer.
http://digidesign.com/index.cfm?lang...4&itemid=29369
Hope that helps!
If you don't have it backed up, do you really have it?
[ Mac Pro 4x2.66 | 3x23" | 5GB | 4x500GB int. - 4x500GB ext. | 10.5.5 | PT8 003R | Command|8 | BM-5A's ]
[ Macbook Pro 2.16 | 17" | 2GB | 1x120GB int. - 2x250GB ext. | 10.5.5/XPproSP2 | PT8 Mbox2Micro ]
Old 06-30-2008, 05:44 PM
I think DP 4.12 runs in Tiger. Any way, I think I'll upgrade my DP. Thanks Phil
Old 06-30-2008, 06:11 PM
I unplugged a Lacie HD I had connected to a Firewire port. The problem was solved. Now I have to look for another port in the Mac to plug my external hardrives.
I also did the upgrade to LE 7.3.1cs6, but the appendix cs6 doesn't appear added to the LE 7.3.1 name. Is it right, or maybe I didn't the install well done?
Old 07-01-2008, 01:43 PM
It's quite normal that the cs6 doesn't appear on the Pro Tools splash screen. You can find/confirm the exact PT version installed from Apple System Profiler/Applications.
6085 error question about 6085 error mbox2 pro MacBook pro unibody 13". HELP TREXROCK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 08-26-2016 01:35 PM
6085 Error OVER AND OVER.... The Tao Of Chris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 05-18-2011 12:19 PM
Error 6085 simon_quinn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-22-2011 06:00 PM
error -6085 stevemitchell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-30-2009 08:17 PM
1 Cure for error 6085 and error 9093!!!!!!!!! CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-23-2002 08:30 AM
