Old 02-04-2019, 06:27 AM
its2loud its2loud is online now
Default Re: No sound on xmon main out
If I were troubleshooting this I would connect an audio source to the Alt inputs of the Xmon to see if audio was able to pass through to the speakers. That’s where I would start, assuming I already knew the speakers were working and wired correctly.
Then I would make sure audio was coming out of the 192 analog outputs. If both of things tested positive then I might consider a cable issue between the 192 and Xmon or an issue with the Xmon Main outs.
Did you do a factory reset on the Dcommand?
Old 02-05-2019, 02:15 AM
lonestars lonestars is offline
Hi everybody, found the problem!
Because I’m using the db25-db25 cable that I was using in the older procontrol sytem, I founded (with the seller’s help) that this particular cable is wired as with the db25 standard diagram connection on interface side, but different wired diagram on the procontrol side, as you can see in the picture.
Now, I need to buy standard dsub25 cable and it should works!
I was sure that it was not a basic configuration issue.
Thanks all for your help!
Best regards
File Type: jpg F153568B-EE88-4E70-AB9E-07984F925A9D.jpg (18.7 KB, 0 views)
File Type: jpg 4E8E7B30-D832-4435-A78E-C2F72C8DFBA4.jpg (27.9 KB, 0 views)
Old 02-28-2019, 03:44 AM
andrej770 andrej770 is offline
As I am sure you realize by now, the MAIN outputs are wired for surround sound. So if you are using a normal AVID DB25 to DB25 cable, you would use channels 1 and 5 in to get the sound from XMON and controlled by D-Control.
Also ensure that you have the (green) L & R buttons pushed under the LED display and that its set to Solo and not Mute. (in the picture you have mute on)
I hope this helps. Feel free to PM me if you need any additional help.
Mac 8 Core 6,1 - OSX 10.13.6 - 32GB RAM - Pro Tools 2018.10 - 8x8x8+8 ch DA Card (x2) - HD OMNI - ICON D-Control 32 - Sync I/O - Sonnet xMac Pro Server w/HDX x 2, Blackmagic Intensity Pro 4K
Protools 2018.10 HD Native in 1 project suite
Eristopher Music
D-Command ES Main Unit + xmon filip_a Buy & Sell 16 11-11-2018 01:43 PM
D Command ES Main + XMON Southsidemusic Buy & Sell 2 01-26-2018 03:07 AM
Selling our second D-Command Main Unit + XMON Southsidemusic Buy & Sell 7 02-19-2017 12:58 PM
D Command ES main unit w/XMON - EU SmartGear Buy & Sell 0 07-18-2015 04:03 AM
WTB: D-command Main Unit w/XMON mtung Buy & Sell 0 05-16-2012 03:33 PM
