Is there a way to convert vst to rtas without vst to rtas adapter?
I have some vst plug ins that are wrapped with fxpansions vst to rtas adapter. Most work, except some dont. Its annoying because some of the plug ins i have are hard to find or arent created in rtas format. Like i cant find a substitute for a vst plug ins with an rtas plug in thats similar to it. I also understand that vst to rtas adapter is guaranteed to work on everything, and it hasnt been updated in years. Its still stressful to not have vst only plug ins not working in pro tools, because vst to rtas adapter cant wrap them. Is there any other way to convert them or a different software that works good?
Re: Is there a way to convert vst to rtas without vst to rtas adapter?
I'd just like to point out real quick that I've found a number of VST plugs will commonly have issues due to an incompatibility with different versions of the operating system & software you're running...and are not always related to FXpansion's wrapper. It can be a little harder sometimes to get the proper updates for the plug (especially if the VST is freeware.) I have a handful of VST's that I never got to work right after I upgraded to Snow Leopard.
....not saying definitively that that is your specific issue, but it's something to keep in mind. |
If you search on Gearslutz you will see Fxpansion acknowledging the forthcoming (but don't hold your breath) VST wrapper 3 to AAX. The only other two RTAS plugs that allow similar and are more successful with certain recent plugs are Maschine (you can set this up so it routes channel audio internally in and out of a VST or AU plug ) and back onto the channel in PT, or Kore now discontinued which did similar. There is also Plogue bidule, which has a VST version for registered users, which you can wrap and then host a plugin within that wrapped plug in, but this has been a little hit and miss as you can imagine!
If you're talking VST instruments - check Reaper and VE PRo , lots of chat on here about them. |
The plugins you are trying with, do they work ok as VST? Have you tried loading them in something like repear to make sure they work as VST? They must actually be working as VST for the wrapper to work!! Which plugins? Have you gone into the wrapper and selected them manually to yes for wrapped? This is what a lot of VSTs need. VE works like a rewire app and routs the signal back to pro tools! Ok for instruments but not for processing plugs. Chris
No one will guarantee that all 3rd party VST plug-ins will function in their host software. There is no control as to coding in out of house software. Plug-in vendors are also responsible for compatibility. Always try the demo in the DAW you prefer before purchasing if you have doubts.
Exactly what plug-ins are you trying to use? Are they the latest versions? Maybe we can help you.
Not any more, VEP 5 Pro will let you stream audio from a track in Protools into a VE Pro channel, through a bunch of VSTs and back out into Protools...
Well i know it can be done and i did this with Logic about 3 years ago, but its a pain for processing. and not ideal for delay compensation. but maybe they have that sorted as well. Chris
To be honest I haven't tried it, I don't have any VST-only plugins really, but the manual claims its all delay compensated, I guess VEPro does it's own delay compensation internally to synch up it's outputs and then reports back to Protools what it's biggest amount of compensation is.
I guess that could get messy :-( |
RTAS adapter, I need one | GMP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-14-2010 08:58 PM |
help on vst rtas adapter....please | jale | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-25-2009 03:51 AM |
VST-RTAS Adapter | marshallman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-16-2004 12:19 PM |
vst to rtas adapter | aishabag23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-13-2004 06:23 AM |
VST to RTAS adapter | Everything | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-12-2004 06:35 PM |
