X-form AudioSuite - preview broken?
I'm using x-form as AudioSuite PlugIn today for the first time. When I select any value for "Transpose" and click on "Preview", PT-HD hangs and the PizzaWheelOfDeath keeps spinning and I have to force/quit PT. When I click on "Process" all works as expected. I searched the DUC for a similar thread but couldn't find any. Is anyone else running in this, too ? Just wanted to make sure before I will contact Avid tech support.
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
Re: X-form AudioSuite - preview broken?
Have you tried trashing preferences yet? Was this ever wroking properly?
I haven't trashed prefs yet. I will do so tomorrow and try again. I just need to finish this one VocalTrack now Thx a lot for your quick reply - I will post my results (with new prefs) tomorrow.
I use X-Form all the time, 8.0.3cs2 HD, works great.
Sig |
same issues here (PT hangs), but only on an elastic audio track (reproducable)
MP5,1 12core 3.46ghz 96GB Ultimate HDX, Monterey https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
I'm not a tech, but did a little digging to see if I could help...
Check to make sure you have X-Form v8.0.1. You can download from the X-Form Product section Or run the combination plug-in updater for Pro Tools 8.0, 8.0.1, and 8.0.3: Plug-in Updater v8.0.3 for Mac OS X 10.6 and 10.5 This is an older Knowledgebase article, so I don't know if it still applies: X-Form AudioSuite Preview Performance
Administrator Avid Pro Audio Community |
I trashed PT-prefs, set them up again, made my settings in the peripherals section again, checked that I'm using x-form 8.01 - - - but all that did not help. As soon as I click on preview, the PizzaWheelOfDeath spins and I have to force quit PT What I'm doing is selecting a small piece of AudioRegion on a regular AudioTrack (No Elastic Audio enabled). Then go to Menu AudioSuite/Pitch Shift/X-Form, set type to "Monophonic" and "Transpose" to about 0.24 semi. Then click on "In" for "Formant" and leave them at 0.00. When I then press preview, PT hangs. When I press Process, all works as espected. Any further tips what I could check ?
I am having exactly the same problem.
Try to use preview with X-Form and program just hangs and the only way out is a force quit. This seems to be a new "feature" as I use x-form a lot for certain sessions and can't remember this happening before. Extremely annoying. Have done all the usual things but makes no difference PT 8.03cs1 HD3 - Mac Pro 8 core 16GB Ram |
Do you have a session you could upload (including and audio file) that exhibits the problem? Also, can you zip up your logfiles folder (inside your Pro Tools folder), upload it and send me a link to the download? I'll take a look and see if it reveals anything... |
I did a new session (no template). Added one AudioTrack. Added a small piece of audio and selected a small piece (6624 samples) SetX-Form to "Monophonic" and tweaked transpose a bit. Result: Spinning PizzaWheel of Death showed up and I had to force/quit PT. Regression: If I do the same using a polyphonic GuitarAudio file AND set X-Form to "Polyphonic", preview works as expected. Here is the screenshot how my settings are looking: http://dl.dropbox.com/u/427719/X-FormScreenshot.pdf And here is my ptf session & log-files for reproducing: http://dl.dropbox.com/u/427719/TheX-...es05202010.zip THx for taking care bout it If you need any further details, feel free to contact me. I'm happy to help you guys :)
X-Form Super slow & Progress Bar broken | TommyT | Pro Tools TDM Systems (Mac) | 1 | 11-14-2011 03:03 PM |
x-form audiosuite preview BROKEN!!?!! | alw4416 | macOS | 0 | 09-15-2011 06:18 PM |
X-Form Broken in 8.0.1? | lightning ad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-13-2009 10:30 AM |
can't ear audiosuite preview, no sound from preview -SOLVED! | sonuslab | Pro Tools M-Powered (Win) | 3 | 03-19-2008 12:51 AM |
audiosuite preview / workspace preview fixed in 7.4? | viaspiaggia | Pro Tools TDM Systems (Mac) | 10 | 10-11-2007 01:02 PM |
