#51
Re: Will elastic audio ever get fixed?
There are no warbles in the Logic version. I suspect that you have very few warp markers in your EA version, so that while there may be less warbling than my EA file, the audio probably never got quantized beyond just a few spots. If you decrease the EA sensitivity below 95%, most all the warbling goes away because most warp markers disappear and no quantizing is taking place. Anyhow, when you send the file I'll be able to tell if it's actually quantized enough.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs |
#52
Yes, the logic one warbles at the end.. not as much but i can clearly hear it. I will manually remove the ridiculous amount of warp markers on the single end sustained note and solve the issue in 10 seconds flat. There is not one single artefact like your file shows at the start and middle.. because you clearly used the wrong algorithm and maybe removed too many markers.. Logic's transient detection has always been accurate, i'll give you that.. that's why you are getting a better instant result.. but for me, to use pro tools over Bogic, i can handle the extra 30 to 60 seconds of work required. Plus, ultimately, radius beats logic complex anyway especially if any reasonable stretching needs to be done. Anyway look I have to go.. I am late to pick up my nieces.. My fault for looking lol.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
#53
No need to send any audio. I didn't use the "wrong" algorithm and I know what EA is capable of and what it is not. I thought you had a tip about this and was eager to learn something new. This is not a competition to me, I just want PT to improve EA, nothing more. So I'm done here, nothing to see.
#54
whatever
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. Last edited by TNM; 03-22-2018 at 08:12 AM. |
#55
I just listened to your EA clip, it's got multiple warbles, nothing I would ever use professionally, so NG.
#56
I don't have the files with me right now, but this is personally my core issue with EA-
If I record my Josephson C700S (which has 3 outputs) in a single LCR track, EA will work as well as stereo or mono does. If I record it into 3 grouped mono tracks, EA functionality has significant problems. Aside from debates about one program being better in one respect or another, can we agree that this is an actual objective problem with EA? Both of these are stored on my computer as 3 mono audio files. There is no real technical reason why it shouldn't be possible to make them work the same here. |
#57
#58
Sure, here it is:
https://www.dropbox.com/s/dvoj9ptjqc...0Test.zip?dl=0 I don't want to go back to Logic either, so I'm using Logic the background just for audio processing/quantizing, while PT is my main program. Logic's Flex Time was already better than EA and now that they've also added Smart Tempo, they are even further ahead of the pack. I still use EA quantizing for simple monophonic material, but anything beyond that and Logic's processing is usually flawless and requires very little to no user tweaking. Logic's advancement in this area is a good thing, because it may put pressure on other companies to at least match capabilities. Or not...we don't know.
#59
Thanks for this!
Yes the Logic one really does sound quite a lot better. Both elastic versions (yours and TNM's) sound pretty bad, they both have that horrible flutter/wobble on the very first G which pretty much gives them away right from the start. TopJimmy's version is pretty good actually but obviously that required a fair amount more work on his part, and even then it still has a couple of low end artefacts, particularly on the 2nd phrase (the Gm 1st inversion). All of which just gets me even more depressed about the current state of Elastic audio really. (And boy have I complained about the sound of it on here over the years ) |
#60
Why Elastic Audio are not installed in Pro Tools 12? Elastic Audio not working :( | ChiLLoUt | Pro Tools 12 | 9 | 01-20-2018 12:56 PM |
Elastic Audio: X-Form vs. Disable Elastic Audio | sharchik | macOS | 1 | 09-22-2014 01:49 AM |
Render elastic audio alert when not using elastic audio! weird! | jjboogie | macOS | 7 | 03-26-2012 09:01 PM |
committing elastic audio in 7.4 is it fixed yet | 2fly | Pro Tools TDM Systems (Mac) | 9 | 01-15-2008 05:08 PM |
Elastic AUDIO, or Elastic TIME? | SoundWrangler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-13-2007 11:21 PM |
