Old 05-05-2012, 04:52 PM
Blackhawk Blackhawk is offline
Default Windows doesn't recognize Mbox?
So just recently (the last few days) my mbox hasn't been recording any sound at all, I tried using a different cable, a different mic, different channels, nothing worked. Then I looked in control panel and saw that it wasn't listed in the devices under recording or playback. However, Pro Tools (LE) still recognizes that it's there and opens, just when I try to record something no sound comes out. Also, the little chime when you plug in a usb device still sounds on my computer when I plug it in.
Old 05-05-2012, 04:55 PM
Default Re: Windows doesn't recognize Mbox?
Oh also, I'm running Windows 7 64-bit with the original Mbox.
Old 05-06-2012, 02:29 AM
zedhed's Avatar
zedhed zedhed is offline
Has the Mbox been working properly on this computer to date?
Win7 needs PT v8.04 or higher to run but Original Mbox is not supported with 8.0.3 and higher
http://avid.force.com/pkb/articles/e...ility/en353241
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 05-07-2012, 01:41 PM
Yeah its been working great, no problems at all until now. Maybe I'm getting the models mixed up, I think its the original because it doesn't have anything that says "mini" or "2" on it
Old 05-07-2012, 05:14 PM
I've read on a bunch of different places that it doesn't work on Windows 7, which is really weird, because its been working perfectly fine. Up until now the computer has recognized it and it's been showing in the device manager. I'm not sure what happened, I didn't change any of the settings or anything. Plus the fact that Pro Tools still realizes its there makes me think its not the interface or the usb/cable.
Old 05-08-2012, 12:48 AM
loginame loginame is offline
Which version of PT are you using?
Old 05-09-2012, 04:58 PM
Le 8.0
Old 05-13-2012, 08:19 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default
Maybe a win update happened ?? Or some other software in the background ??
I personally abhor Microsoft's auto update feature
Daniel
Old 05-13-2012, 07:55 PM
Total luck aside(albeit temporary) Windows 7 requires 8.0.4 or later and the old Mbox(gen 1) won't work past 8.0.1 so I would recommend either getting a newer interface(Mbox 2 or 3, used 002 or 003) and the 8.0.5 update. The other option is to dump Windows 7 and install XP(or setup a dual boot, or swap the Win7 system drive with another drive and load XP on that).
Windows 7 won't recognize my Mbox 2 wrykse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-27-2012 08:39 PM
Windows 7 does not recognize Mbox 2 rivers. Hepl me please !!! Hovak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-30-2010 02:25 AM
Windows 7 / PT8.0.3 doesn't recognize internal hdd scadh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-16-2010 11:27 AM
Windows wont recognize MBox soundman6 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-12-2009 09:35 AM
How much RAM can windows recognize ? Violet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 12-15-2008 09:11 PM
