Pro Tools 10 Delays or Freezes when exiting application
Okay so I was trouble shooting this all night just to get the program to work. I finally get this to work perfectly but now every time I exit protools 10 it takes a really long time to close. I timed around 30 seconds everytime. If I attempt to retry to close it while its already trying to close it freezes. Anybody else having this issue?
Alex "Q-Dash" Medina CEO, ABR Productions LLC Audio Engineer Producer, Writer |
Re: Pro Tools 10 Delays or Freezes when exiting application
Post a Sandra Report of your system, please.
Aaron Mulqueen - 001 HD Native |
Audio Interface: Digi002 RACK
OS: Windows 7 Ultimate 64 bit Service Pack 1 Processor: Core i7 920 2.67 Memory: 6 X 2GB = 12GB RAM Internal Hard Drives: 500GB (C:) OS/Pro Tools/Plugins 2TB (D:) Protools Session Projects 1TB (E:) Library for sounds and finished songs Sandra Report: ----------------------------------- SiSoftware Sandra Computer Model : OEM System Product Name Workgroup : WORKGROUP Host Name : ABRStudio-PC User : ABR Studio Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.81GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : ASUS P6X58D PREMIUM BIOS : AMI (OEM) 0604 01/21/2010 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 12GB DIMM DDR3 Chipset Model : ASUS X58 I/O Hub Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Chipset Model : Intel Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Total Memory : 12GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 536MHz (1.07GHz) Memory Module(s) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Video System Video Adapter : NVIDIA GeForce 9800 GTX+ (128 SM4.0 1.84GHz, 512MB DDR3 2.2GHz 256-bit, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce 9800 GTX+ (128 SM4.0 1.84GHz, 512MB DDR3 2.2GHz 256-bit, PCIe 2.00 x16) Graphics Processor Compute Shader Processor : NVIDIA GeForce 9800 GTX+ (128SP 1.84GHz, 512MB DDR3 2.2GHz 256-bit) Storage Devices WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, 32MB Cache) : 466GB (C:) WDC WD1001FALS-00E8B0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (E:) Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm) : 2TB (D:) TSSTcorp CDDVDW SH-S223L (3.9GB, SATA150, DVD+-RW, CD-RW, 2MB Cache) : 4GB (F:) Logical Storage Devices System Reserved : 100MB (NTFS) Library (E:) : 932GB (NTFS) @ WDC WD1001FALS-00E8B0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Protools (D:) : 2TB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm) Hard Disk (C:) : 466GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, 32MB Cache) PART 16 (F:) : 4GB (UDF) @ TSSTcorp CDDVDW SH-S223L (3.9GB, SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13 Audio Device : ASUS HD Audio Controller Audio Codec : Realtek Semi High Definition Audio Disk Controller : ASUS 4 port SATA IDE Controller Disk Controller : ASUS 2 port SATA IDE Controller Disk Controller : ASUS 88SE914D SATA-600 Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : ASUS VIA VT6308 1394 OHCI Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller (Ethernet) Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2 (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.9
my bios has my target dram frequency at 1066MHZ...Im not really to savvy when it comes to tweaking bios settings. Is there any recommendations for optimal results?
I have the same problem, when I close Pro Tools 10 it takes like 5 minutes to close. the screen goes white with you try and close it again
Producer/Engineer/Musician RIAA Platinum Sales Award: Lisa Stansfield "Affection" Main: Model: Dell 5750 Precision Workstation OS: Windows 11 Pro 64bit CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz, Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD Focusrite Scarlett 18i20 3rd Gen AVID Pro Tools 2023.12 JBL LSR4328P 8" JBL LSR310S 10 inch Powered Studio Subwoofer* Yamaha HS50M Studio Monitors Alesis Elevate 3 Studio Monitors M-Audio Axiom 61 Midi Controller |
Yes I have actually had problems with 1394 blinking sometimes on my firewire device. Its more of a synchronization problem sometimes. Any fix action recommended?
Call your RAM manufacturer support to run you through clocking the RAM to 1333 or 1600 MHz.
SIIG FW Adapter.
My open and exits are fine but I am getting freezes during sessions. I can't be sure but twice it happened while tracking with the new channel strip on the armed track.
Pro tools application error! Help | GetBusyKid1043 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-23-2011 05:08 PM |
W7 install freezes at application files | chrislasais | Pro Tools M-Powered (Win) | 0 | 02-18-2010 10:55 AM |
I'm having problems shutting down. PT freezes upon exiting | sircharles2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-19-2009 03:34 PM |
When Exiting Pro Tools Getting R6025 Error | David H. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-20-2008 08:41 PM |
Akai MPD-24 causing Pro Tools LE to Hang While Exiting..!!! | Spyda KB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-08-2008 02:34 PM |
