Old 01-22-2011, 10:06 AM
LSNY LSNY is offline
Default Upgrading to SL and PT 9. Questions re latest versions.
Macbook Pro 2.4 Intel Core 2 Duo w/4 gigs RAM
1. First: Going from Tiger 10.4.11 to SL
2. Then: From LE 7.3.1 to 9
Update Questions:
I assume the SL upgrade disk will be something like 10.6.3 (or 10.6.2)
I'm guessing I should not update that to the "latest" 10.6.6 yet? Is it ok to run whatever version of 10.6 is on the disk, and not update yet?
Same question re: PT9. Should I first install and run PT9 before I update to 9.0.1 ?
Thanking you all in advance!
Larry
Old 01-22-2011, 10:48 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Upgrading to SL and PT 9. Questions re latest versions.
I haven't seen 10.6.6 officially approved yet. Do the combo of 10.6.5.
Install the drivers for the hardware you are using then 9.0.1 then the midi fix.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 01-22-2011, 11:02 AM
crizdee's Avatar
crizdee crizdee is offline
Larry
9.0.1 is an update and available for download as an update for users who already have PT9 installed. But if you log into your Avid account 9.0.1 full installer is available which needs no previous version installed.
I have seen some users try installing just the update with no previous version installed!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-22-2011, 08:16 PM
Right...I've purchased the Crossgrade to PT9. Will have the disk next week.
Old 01-24-2011, 01:58 PM
Jeffrey Talbot Jeffrey Talbot is offline
FWIW, I've been on 10.6.6 and PT9.01 for a while now and everything is peachy.
Old 01-24-2011, 03:10 PM
Thanks !
Just out of curiosity, what kind of machine are you running it on?
upgrading to latest version poolio1971 Pro Tools M-Powered (Win) 2 03-15-2011 05:05 AM
How do I download all the latest versions of my VI's? Paul David 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-26-2010 03:41 PM
Anyone know how you register Massey plugs to get the latest versions? crizdee Pro Tools TDM Systems (Mac) 5 01-11-2009 05:43 PM
upgrading to latest Le 7 4 gracec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-23-2008 08:06 AM
not upgrading to the latest version??? protuser 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-15-2005 11:09 PM
