Digital noise on 888/24 inputs 1&2
Hi, I have a ProTools Mix system with 1 MixCore, 3 MixFarms and one DSPFarm.
I have a 888/24 (A) attached to the MixCore card, a 1622 (B) to the first MixFarm and a 888/24 (C) to the second MixFarm. Whenever I try to send signal to the input channels 1&2 of the second 888/24 (C), I get loud digital noise. It works fine if it's connected to the MixCore. I also tried to combine the cables between the audio cards and the 888's. The worst case is that all inputs and outputs make this loud digital noise. The best case is that everything works fine, but these 2 inputs. It used to work fine until now. Suddenly it started doing this thing. Anyone can help? Thanks. Nico |
Re: Digital noise on 888/24 inputs 1&2
Thanks for your reply.
I'm pretty sur it's not that because if I attach 888C on MixCore and 888A on MixFarm, 888C has no more problems, but the problem appears on 888A. And if I change only the cables, the problem can be even worse. |
Digital Inputs | james tebb | VENUE Live Sound Systems | 0 | 04-15-2009 03:40 AM |
16 Digital inputs? | Tim Martin | Tips & Tricks | 1 | 11-28-2008 10:39 AM |
Digital Inputs - Can I do this? | Muzoid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-19-2007 06:05 PM |
Digital noise on two 192 inputs...help please | Jack Ruston UK | Pro Tools TDM Systems (Mac) | 2 | 12-05-2006 02:06 PM |
96 I/O digital inputs | Nika | Pro Tools TDM Systems (Mac) | 5 | 06-26-2002 12:47 AM |
