PT compatibility with Media Composer ?
my first post here. I am thinking of buying PT LE in addition to the Avid Media Composer but before I got a question regarding compatibility issues: Some times ago there were some discussions after what it seems not to be possible to work with PT LE and Media Composer if both applications are installed on the same partition on the hard drive. Is this still the case or was there a fix for that in the meantime ? I am not sure if this is the right place for this question but I asked this some times ago in the avid forum and got no response. So maybe someone from Digi could clarify if I have to expect problems with both applications on the same partition or not. Thx Jan |
Re: PT compatibility with Media Composer ?
you will get more traction in the Post section but the answer is still separate partitions
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Craig is right - separate partitions is currently the only way to go.
Thanks for clarifying this.
AAF Files From PT 9 into Media Composer 5.5/TRUE COMPATIBILITY | mysteron | Post - Surround - Video | 13 | 07-14-2011 11:44 AM |
Media Composer 4.05 - OSX 1O.6.4 anyone? | MIKEROPHONICS | Post - Surround - Video | 1 | 09-07-2010 10:45 AM |
1.0 and Media Composer 10.0 | EasternSky | Post - Surround - Video | 14 | 06-01-2001 05:44 AM |
Media Composer/A.V. OMF | Rick Sanchez | Post - Surround - Video | 5 | 01-11-2000 12:19 AM |
Media Composer/A.V. OMF | Rick Sanchez | Post - Surround - Video | 0 | 11-23-1999 09:43 AM |
