Old 11-14-2015, 09:34 AM
Eric Lambert's Avatar
Default Nudge behavior is different in PT12?
I upgraded from 11 to 12.3 and the very common process of nudging MIDI notes is changed, or more likely a setting was changed and I've just been unable to find it. I did look at every menu, preference -- it's clearly just falling past me.
Here's the issue: if I use the Grabber to select individual MIDI notes I can then hit + or - on the number pad and those notes will slide by the nudge amount, as expected. That's how it worked in all version of ProTools. HOWEVER, when I select a series of notes with the Select tool, hitting + or - only slides the area I have selected, it doesn't actually move the MIDI notes earlier or later in time, which is what I want.
What am I missing? What got reset?
Old 11-14-2015, 09:41 AM
Oli P Oli P is offline
Default Re: Nudge behavior is different in PT12?
I have the same issue in PT 12.2
www.olipoulsen.com
iMac27 i9 3.6 (late 2019) / 64 GB Ram / OS 10.15.7
Apollo 8 / PT Ultimate 2020.9.1
Old 11-14-2015, 10:08 AM
Stig Eliassen's Avatar
I assume you're nudging in the edit window? It works with both selector and marquee tool in the MIDI editor here in 12.3.
Old 11-14-2015, 11:28 AM
Top Jimmy's Avatar
Just to be certain, you are in notes view correct? If that's the case, does it still happen if you select the first note and then shift-select the last note?
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.4.
Pro Tools Ultimate 2020.12, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Old 11-15-2015, 01:25 PM
Notes view, velocity view, etc. With previous versions of PT I could be in any mode where individual notes are shown (i.e. not as clips) and nudging with + or - would move the notes as expected.
I've changed nothing in PT12 but can't notes selected via the Selector tool to nudge.
If I select the entire length of the track I can nudge them, but that's useless when I'm looking to nudge small sections.
This is actually a big deal as much of our workflow is done by selecting bars and sliding them around.
Was something changed in PT12? Or am I just missing a setting to adjust this behavior?
Old 11-15-2015, 01:28 PM
Edit window, yes. It doesn't matter if we select the first and last note. The only way to get MIDI notes to nudge via the Selector tool is by grabbing the very beginning of the clip (which might begin BEFORE the first MIDI note) and extending the selection beyond the end of the clip (which again might extend beyond the last MIDI note).
This is making MIDI editing difficult.
Old 11-16-2015, 05:37 AM
Eric, are you able to nudge a selection containing notes, WITH the notes, if you disable Automation follows edit? That's what happens here.
Old 11-16-2015, 08:09 AM
I'm almost certain that I toggled that function but I'll check again. PT should nudge MIDI notes with that function on *or* off but let's find out what's causing the issue.
Old 11-16-2015, 08:28 AM
I can confirm that when "automation follows edit" is turned on MIDI notes cannot be nudged in either direction. Nudging merely moves the area which is highlighted.
Also, when automation follows edit is turned off it will move MIDI notes *and* the automation is affected, too.
It seems like neither behavior is quite correct.
Old 11-16-2015, 09:14 AM
Something is definitely a bit off. Thanks for the info. I'll do some more testing when time permits.
PT12 and PT12 HD surround? theom Pro Tools 12 17 10-12-2015 10:27 AM
nudge again paldry macOS 4 09-12-2011 11:32 AM
Possible to change direction of Nudge 1/Nudge 8/Nudge Bank switches? EricHirsch ICON & C|24 1 08-13-2009 09:07 AM
NUDGE BUG NUDGE BUG!! Why wont you go away you little weasle?!?! Mt.Everest Pro Tools TDM Systems (Mac) 4 09-07-2001 12:17 AM
Nudge bug is in 5.1.1 too ripple FX Pro Tools TDM Systems (Mac) 8 07-15-2001 10:18 PM
