Old 06-24-2013, 02:59 PM
oldgitguy's Avatar
oldgitguy oldgitguy is offline
Default Can I adjust gain on just one track in?
Hello everyone.
I'm running PT11 with an 11R.
I have a backing track I made playing on track 1.
I have an mono audio track (2), setup for the dry track, (Guitar in), (Main out).
I have a stereo track (3), setup for the wet track, (11R L/R in), (Main Out).
This way I can have both tracks recorded simultaneously.
I select record enable on track (2), (3).
I press record then play and record my guitar.
When I play it back the dry track is very low volume but the stereo track is normal.
I cannot find anything in the forum or manuals on this and was curious if I'm not doing something to increase gain on the dry track guitar in and if I even can do that.
Am I missing something somewhere where I can increase gain on that track alone?
Thanks.
Old 06-24-2013, 03:10 PM
TheChimp's Avatar
TheChimp TheChimp is offline
Default Re: Can I adjust gain on just one track in?
That's actually normal. The level of the 'dry' guitar track is optimized for re-amping through the Rack. If you need to gain up the dry signal, you can just use clip gain to do that. I hope that helps!
_______________________________
The Chimp
Delivery Manager/CSM, Guitar Products/AAX Plug-ins
P&S Creative Professional
AVID
Old 06-24-2013, 03:16 PM
oldgitguy's Avatar
Thanks so much. I will read up on that and give it a try.
Old 06-24-2013, 03:21 PM
oldgitguy's Avatar
Yep. That really helped. Thanks. I appreciate the fast feedback.
This forum is great!
adjust clip gain with dcommand zakco ICON & C|24 0 06-25-2013 06:27 PM
Adjust input gain of Guitar in (ASIO) ThunderKyss Eleven Rack 9 04-16-2013 05:16 AM
How to adjust gain on 003R inputs 5-8 Matt Rushmore Pro Tools 9 15 05-04-2011 10:01 PM
How do i adjust gain on 003+ Maddawg383 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 25 03-09-2009 07:24 AM
Output gain adjust? stainless Pro Tools M-Powered (Mac) 1 04-17-2006 09:43 AM
