While bug hunting for this thread:
http://duc.avid.com/showthread.php?t=312119 I thought I would also mention something I noticed about the DYN III compressor a while back, but never reported. For some reason the DYN III compressor does not seem to work until the Ratio knob is turned. The Gain works, but there does not seem to be any actual compression until the Ratio knob is nudged. I show the above behavior in the following video. You will see that you can take the Threshold all the way down, and nothing happens until you nudge the Ratio knob. It would be nice if some other people could test this out as well. Eleven Rack DYN III Compressor Bug - YouTube
Brian Windows 10 Pro 64 Bit Pro Tools 2020 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Ok, so I tried some other scenarios.
Now it seems that presets with the compressor do have the settings remembered, but there is a bug when changing the threshold, you have to first adjust Ratio. It seems when you first select the DYN III all knobs will work fine, including the threshold. But after saving the Rig, then you get problems with the threshold knob not working or causing wild jumps and then the ratio causes the compressor to work properly again. A video on this is coming....
So this video shows that it seems that the DYN III acts normally when FIRST selected, and it seems to retain the settings/compression after changing rigs then coming back. But as soon as the Threshold knob is touched, it seems to lose compression, then compression returns after the Ratio knob is touched.
Eleven Rack DYN III Bug - Video 2 - YouTube
Thanks Benoni
Has anyone else had the time to test this on their 11R?
Hi Benoni
I've checked, same issue. So it's a bug |
i hope they can fix this bug along with the XTC green bug and the other bugs that have been reported lately in a free firmware update within the next couple months.
Hey Benoni. What is the XTC green bug? I haven't been able to find it. Thanks!
_______________________________ The Chimp Delivery Manager/CSM, Guitar Products/AAX Plug-ins P&S Creative Professional AVID |
Hey Chimp. Check this thread-
http://duc.avid.com/showthread.php?t=312119 Looks like Chris T confirmed the bug back in November. |
FS: Eleven Rack with ERXP | adflaker | Buy & Sell | 3 | 06-15-2012 05:11 PM |
Solved: "Avid Eleven Rack Updater" not copied to Desktop during ERXP install. | rwmacdonald | Eleven Rack | 8 | 03-22-2011 08:30 PM |
Eleven Rack Expansion Pack (ERXP) FAQ | DigiTechSupt | Eleven Rack | 0 | 03-21-2011 07:47 PM |
Eleven Rack Expansion Pack (ERXP) Firmware Updater incompatible with IE9 | DigiTechSupt | Eleven Rack | 0 | 03-21-2011 10:14 AM |
