Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 10-10-2011, 09:54 PM
Sonic Blue Meanie Sonic Blue Meanie is offline
Default External Hard Drive Fan?
I've got a Lacie d2 Quadra Making a noise repeatedly. Hard to describe, but sort of a little 2 second spinning noise that starts and stops, but repeats continuosly. I think it might be the fan because I can feel a little pulsating air movement when I put my hand to the vent.
Ready to spring for a Glyph, but had to check in here first just in case. Also wondering if the power supply might be failing?
Mac OS High Sierra
Version 10.13.6
3.5 GHz Inte Core i5
8 GB
Protools First/Scarlett 2i4
Old 10-11-2011, 10:35 AM
Default Re: External Hard Drive Fan?
Could be the power supply, but more likely the fan itself, or the circuit that tells it how fast to spin. I have some Lacie drives here and have never been all that impressed. Much happier with my OWC drives. Glyph is king, but has the price to match
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 10-12-2011, 08:16 AM
aka21stCentury aka21stCentury is offline
Does it almost sound like a square wave? In twos....? Could be the heads moving fast looking for the boot rom section.
Old 10-12-2011, 12:41 PM
HFS+ or NTSF? Sorry to hear about a potential disk failure. Are you certain it is not the connector (D.C. in?) ???
Is there an LED on the unit? Does it go off and on if you simply touch the connector. (some OWC models with fans have the transformer built in, AC in, not DC in).
If drive lunches on a Mac good news is sometimes possible to fix it with Diskwarrior 4.2/4.3 or at least get it running enough to clone it or if not, then archive and reinstall OS. But I'd change ownership on entire drive if that is the case and copy data over. You can smack the end of the drive while powered up held tightly out of the enclosure I.E. to restart the platter. (Two beat square wave buzz - which may be the heads vibrating) to get the platters spinning back up. We did this on tour in Atlanta with an EMAX II, HDD, of course we didn't carry 300 diskettes as a backup. Those were Quantum SCSI drives as in the early Macs and yes, even these you can smack the noncabled end to sometimes get the platter spinning (mind you this is a last ditch effort or you will have to send the drive to Marin County to Drive Savers).
I was able to smack a Caviar just recently and the platter spun up, the heads no longer vibrating, allowing it to attempt a book (and Diskwarrior)... but clone it immediately (SuperDuper)... and watch for 'slow down' error from Diskwarrior (if drive is malfunctioning).
WARNING -- some of my enclosures have D.C. inputs not AC. internal transformers and fans. Don't mess with open enclosures if AC power enters the external case unless you are an EE or trained electrician! 120-240 volts! OWC sells a D.C. powered 'Swiss Army' knife raw drive connector one could use to encourage the platter to spin up. Sometimes static causes it to freeze up... or heat messing with the bearings.
External dedicated external hard drive JuanCarlos General Discussion 1 02-15-2010 04:11 PM
External hard drive mix-up/ bzb888 Pro Tools TDM Systems (Mac) 2 09-13-2007 09:29 AM
External Hard Drive vs. System Drive evman108 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-30-2006 02:49 PM
Help External hard drive w/Le javdon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-22-2002 04:54 AM
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be Fucius General Discussion 4 03-20-2002 12:26 AM
