why can't i do this? i'm bussing the instrument track to bus 7-8 and putting bus 7-8 as the input on a audio track ..
why isn't this working?? just trying to get the midi to a regular audio track |
This is how I print VI's to audio:
Perhaps you aren't turning the bus output up. Alt click on the fader to set it to unity gain.
Also, did you record enable the audio track? When you do print it, mute the instrument track so you only hear one signal.
Jim Carroll Last edited by fenderrocker; 11-23-2010 at 05:55 AM. Reason: fixed |
![]() Quote:
This is sort of crude, but in lieu of a screen shot, the two columns below represent what I've got when I look down the fader channels. The one on the left being the instrument track and the Audio track on the right.
Hopefully you might be able to spot where I've gone wrong. Under this arrangement when I hit play, the Instrument & Audio track get signal, but when I hit record (with track enabled) Instrument does but Audio does not. INSTRUMENT TRACK..........AUDIO TRACK ALL REDRUM -10 v117 p>0< Mute ____________..................._____________ Reason Adapted.................Reason adapted - - - - - - _____________..................______________ a 1-2 _____________..................._____________ A 1-2................................A 1-2 - - - - - - ______________................______________ A 1-2...............................A 1-2 A1-2................................A 1-2 AUTO READ.......................AUTO READ F.....................................F A....................................A D....................................D E....................................E R....................................R
Mac OS High Sierra Version 10.13.6 3.5 GHz Inte Core i5 8 GB Protools First/Scarlett 2i4 |
Reason adapted should only be inserted on the instrument track, not on both. On the instrument track you will get the audio from Redrum rewired into Pro Tools, so that's one step closer.
Then, you need to bus the audio coming in on the instrument track to the audio track. So, you create a send on the instrument track by clicking on one of the send slots, and there you choose any free bus pair. Let's say Bus 1-2. Make this send pre-fader, and set the send level to unity gain. Navigate to the audio track, and select Bus 1-2 as the audio inputs for that track. Record-arm the audio track, and start recording Redrum as audio. I always mute the instrument track and match the levels between the instrument track and the audio track, but this is of course optional. It doesn't affect the recording at all. But I prefer that the mix stays the same while printing VIs to audio.
Kontakt 5 with LASS on a midi track bussing to an audio track | Ambient Dreamer | Windows | 0 | 08-19-2012 07:22 AM |
Please help! Signal from Instrument Track appears in Aux/Audio Tracks unintentionally | JimDC | macOS | 2 | 05-07-2012 10:02 AM |
Problem bussing audio from one track to another audio track | harryk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 08-04-2010 01:15 PM |
No signal when bussing to an audio track. | lalalandguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-02-2009 08:35 PM |
latency on bussing midi/redrum to audio tracks | msg6794 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-08-2005 08:11 AM |
