Old 04-12-2009, 12:23 AM
timstar78 timstar78 is offline
Default MacBook RAM/Performance Issues
Hi...I am hoping for some recommendations/help.
I have a late 2007 MacBook
Processor 2.2 GHz Intel Core 2 Duo
2 GB RAM
I run Pro Tool 7.4.2 with a Digi 002 Rack and have a 500 GB Fire Wire drive.
A couple of my latest recordings have featured a lot of tracks and plug ins. The problem is that I still need to add tracks and I am starting to get the usual error messages regarding CPU power and buffer size. In my latest song, I am running plug ins such as EZ Drummer, Amplitube and TRacks 3 and it really seems to be slowing my system down. My Activity Monitor showed that 1.8 GB of my RAM was being used and about 85% of my CPU power.
If I upgrade my RAM to 4 GB, will this help my situation? Anything else I can do to improve the performance of my computer? Or, is my computer just not going to be fast enough to keep up with all this activity?
Thanks, in advance...
Old 04-12-2009, 07:21 AM
Default Re: MacBook RAM/Performance Issues
I have been told by two Pro Tools instructors, that 4 gig of RAM is the happy zone so it couldn't hurt. From what I have read, the T Racks stuff seems to take a lot of 'juice" and many of the amp sims do as well, so if you are using more than one of each, I would save the Amplitube settings as a preset and then duplicate the playlist and process using AudioSuite for your Amplitube tracks. When you get to this point, I assume you bump up the buffer to 1024?
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 04-13-2009, 09:31 AM
DigiTechSupt's Avatar
If you want a second opinion, getting more RAM is a good idea, but it's unlikely to improve performance of plug-ins all that much. Albee's suggestion about using A/S to print the plug-in is spot on.
Avid Audio Tech Support
Support FAQ
Old 04-13-2009, 09:17 PM
Thank you for the replies. I've since upgraded to 4 GB RAM and that has seemed to help.
Could you elaborate on the AudioSuite idea? Currently, I have four separate guitar tracks, each of which have the Amplitube plug-in. I am not sure I am following what you are suggesting?
Old 04-14-2009, 01:19 AM
state of the arb state of the arb is offline
I'm having a similar problem except I don't think I should be having one. I just recently purchased an Mbox2 Mini and I get the CPU & HW buffer errors often. Problem is my CPU usage in activity monitor doesn't even show 50%. I only have about 5 tracks (3 instrument & 2 audio) with two EQ's and one compressor. Surely this can't be right? It feels to me that my Pentium 4 running Cubase SX 3 could handle more and that simply can't be true. It will be the disappointment of a lifetime :)
Any ideas?
Old 04-14-2009, 02:22 AM
flommer flommer is offline
What they are saying is to render the plugin's effect to audio so you can eliminate the plugin. You can bounce to another track or use the audiosuite versions of the plugins to render "offline"
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 04-14-2009, 02:26 AM
Any ideas?
Wrong forum.. Try the windoze LE forum. (or are you currently using a Mac?).You're also going to have to post more info like PT version, OS, etc...
My guess is that your p4 is behind the curve compared to core2 duo etc, kind of like g4 to intel Mac. Hopefully the peecee guys can help you optimize..
Old 04-14-2009, 04:44 AM
I'm using a MacBook Pro 17". Sorry, only updated my details after the post.
I think I found the problem though. I assigned both processors to RTAS so there was nothing left for the Mac. I changed to only one processor now and it looks better, will check it properly tonight when I get home.
Old 04-14-2009, 11:36 AM
Also make sure you are recording to an external firewire drive (not the internal system drive and definitely not a USB drive).
Obsidian Dragon
Model Name: MacBook Pro
Model Identifier: MacBookPro14,3
Processor Name: Intel Core i7
Processor Speed: 3.1 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 16 GB
MacOS 10.15.7 running Protools 2020.12
Old 04-14-2009, 12:11 PM
color me bad color me bad is offline
^^how do you set up the changes to make the recordings go on the firewire drive?
Advice on macbook pro and mbox performance issues TheElectricGhost 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-16-2007 02:48 PM
Mbox & Macbook Pro performance issues Sebastian C. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-23-2007 09:37 PM
Performance of Macbook (Pro) rmccam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-19-2007 11:05 AM
macbook performance Bologma Pro Tools M-Powered (Mac) 12 04-16-2007 10:16 AM
Performance problem on Macbook Pro Palli-Moon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-04-2007 04:25 PM
