Old 03-18-2005, 12:05 PM
Bixby Bixby is offline
Default Mbox ASIO driver not working with Sound Forge 8
I was excited to hear Sound Forge 8 has ASIO support.
So to test, I installed the Digi ASIO driver and the trial version of Sound Forge 8. Problem is, Sound Forge doesn't show the mbox as an input/output option.
Is anyone successfully running this combo? Is there something I can do to make sure the Digi driver is properly installed (I've already removed and re-installed it once)?
Thanks-
Old 03-18-2005, 01:49 PM
Ducky Ducky is offline
Default Re: Mbox ASIO driver not working with Sound Forge 8
See if Reason or Live sees the ASIO driver in stand-alone mode.
If you loaded Sound Forge before the driver, it may have conflicts.
ASIO MBox Driver Not Working!? Markus7 Pro Tools 9 2 12-08-2011 01:48 PM
Mbox 2 driver issue with sound forge 8b SethC General Discussion 0 11-23-2005 10:52 AM
Sound Forge 8 and ASIO gerax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-30-2005 07:46 PM
ASIO Driver with Sound Forge?? nukmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-08-2004 11:52 AM
Driver for Sound Forge 7 kixx General Discussion 1 02-10-2004 05:57 PM
