Using main analog outputs to master a recording
I have been using the 1/4" monitor outputs to powered monitors & bouncing sessions to my computer via fire wire. Now I would like to use the main analog outputs (or alt main outs)(or optical out) to master recordings on a Sony CDR-w33 CD recorder. The problem I'm having is I'm not getting any signal from either output. (no luck w/optical out either) Am I forgetting to turn something on to route the signal to these outputs. I have checked the user's guide and have not found any info on this. From what I've read it (the manual) assumes there is a -10 db line level signal coming from the output, there is not. How do I make this (any of these) output(s) active? Thanks in advance-Billy Bacon.
PS. the only active signal I'm getting(from the digirack) is from the monitor out & The headphones. |
Re: Using main analog outputs to master a recording
Need more info here. What interface? What does the Sony have for available inputs? and, more importantly, WHY do you think this will give a better result?
How to use outputs 1-2 on Digi003 without getting main mix? | se.audio | Tips & Tricks | 10 | 12-21-2020 09:16 AM |
Using main analog outputs to master a recording | Billy Bacon | FireWire & USB Audio Interfaces (Win) | 3 | 10-01-2014 05:34 AM |
Amp outputs same level as Main outputs? | DonaldR | Eleven Rack | 0 | 02-07-2013 01:50 PM |
Those who go direct, Main outputs or DI box? | Jd0g33 | Eleven Rack | 7 | 11-01-2011 08:27 PM |
Use DIGI-001 as main outputs for Mac? | birdFEEDER | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-14-2003 12:02 AM |
