A problem with project from another comp.
My band recently recorded in a pro studio, and I took the project files home on a disk to edit and mix them from my home studio. I've been working with protools for a little while now, and have been having no trouble mixing down and burning tracks to a CD to test them out.
Now that I'm working with these projects recorded on another computer, settings have gone haywire, options have changed, and I can't burn anything to a disk except as data. I had been bouncing things with settings as follows: Bounce Source: Out 1-2 (Stereo) File Type: WAV Format: Mono (summed) Resolution: 16 bit Sample Rate: 44100 After loading these new project files, the bounce source options are different, so now I only have: Analog 1-2 S/PDIF L-R (Stereo) Analog 1 (Mono) Analog 2 (Mono) Everything else I seem to be able to set the same. Everything still render as a WAV file, but somehow it is unplayable except on the computer, and it is burnable except as data. Does anyone have a clue how to solve this, and why the problem arose. I will say, the version of protools I have is older than the one at the studio... but everything seems to work fine except for getting it off the computer. Thank you all. |
Re: A problem with project from another comp.
Change your I/O settings to the way you normally work. Then see where you are from there.
Manual Delay Comp Problem | WinTaper | Pro Tools 9 | 74 | 09-28-2020 10:01 AM |
PT 10.0.0 HD Native Automation Problem with Delay Comp | Chris Trent | macOS | 5 | 01-07-2012 03:04 AM |
BIG, MAJOR PROBLEM i7 comp gurus plz help! | HDK_Ent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-16-2010 03:12 AM |
Problem with Delay Comp. and not enough DSP/Time slots... | storm-01 | Pro Tools TDM Systems (Mac) | 0 | 08-16-2007 01:54 PM |
horrible comp problem | mbuono | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-04-2003 07:04 AM |
