Old 10-16-2006, 09:59 AM
ardy ardy is offline
Default Problem Opening PT Session
Any suggestions? I am unable to open up a recent session. PT locks up in the middle of reloading the session?
Old 10-16-2006, 10:17 AM
myke2242's Avatar
myke2242 myke2242 is offline
Default Re: Problem Opening PT Session
try making a copy of the PT doc. create new session and import the session data from the wacked doc
_____________________
HerronSFX.com
Herronsound.com/blog/
HerronSFX Instagram
Old 10-16-2006, 10:18 AM
Stig Eliassen's Avatar
Very little info to go on here...
Have you tried importing the tracks into a new session?
Old 10-16-2006, 03:53 PM
myke2242's Avatar
didnt i just say that?
HerronSFX.com
HerronSFX Instagram
Old 10-16-2006, 04:53 PM
Yes, you sure did. If you look at the time right below the subject title...
You win - no worries.
Old 10-16-2006, 08:11 PM
myke2242's Avatar
That is just sick!! your such a good sportsman. I'll concede a tie
HerronSFX.com
HerronSFX Instagram
Old 10-16-2006, 09:41 PM
More facts. G-5 computer, 6 gigs Ram. When I try to open the session I see PT restoring tracks and activating inserts. It is at this point that the computer freezes. I tried to open a new session and import the bad session. Same freeze when restoring tracks/activating inserts. I tried opening new session without some of the audio tracks. Same freeze. I appreciate all of your thoughts.
Old 10-17-2006, 04:01 AM
myke2242's Avatar
try trashing your PT prefs, repair your system premisisons and disk. If that doesnt work you could E-Mail the
session doc and ill see what and if there is anything i can do.
HerronSFX.com
HerronSFX Instagram
Old 10-17-2006, 05:24 AM
garret garret is offline
Import each track one at a time into a new session. It's probably a particular track or plugin causing the issue. You should be able to pin point which track by importing one at a time
IMDB
Old 10-17-2006, 11:31 AM
Thank you guys! You are great! I back up and running.
Problem Opening A Session! HELP!! sant 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-12-2011 12:24 AM
7.4 Opening New Session Problem RichrdC Pro Tools M-Powered (Win) 7 04-04-2009 05:09 PM
opening session problem -wem- 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-28-2008 04:53 AM
problem with opening session please help!! mikefradis Pro Tools TDM Systems (Mac) 3 10-14-2002 10:36 AM
Problem opening PT 3.2 session Magnetic Pro Tools TDM Systems (Mac) 1 05-03-2001 08:16 AM
