Re: Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs
Thanks |
I have a Corda HeadAmp 1 Mk. II (about ten years old?) that either gets connected to the XLR main outs on the Eleven Rack with XLR to RCA cables (I made mine, just follow the standard diagrams on the web or these are easy to find pre-made) or is is connected to the RCA stereo record out loop of the pre-amp that drives my main amplifier. In any case play with the Eleven Rack volume and the Corda volume to hear what sounds better. That Corda is a great headphone amp.
If you have a headphone amp with digital input then I'd try connecting to the digital output of the Eleven Rack. I've got my eye on one of those benchmark DACs... Darryl |
Thanks Darryl Ramm. Here's what I've come up with, and it sounds great:
S/PDIF out to my DAC. RCA outs from my DAC to my tube headphone amp. I'm running my iPhone or iPad into the FX Returns using a line out dock with a stereo mini plug from the iDevice into a cable with a female stereo mini jack on one end and two 1/4 mono TRS male plugs on the other. You could also use a stereo mini cable straight from the headphone jack of an iDevice into the mini jack/dual TRS cable, but I think the dock output sounds better. I'm controlling the mix from my iDevice on the FX Loop screen on the Eleven Rack. I can adjust the overall volume through my tube amp and the Eleven Rack Volume knob. The DAC I have supports 96khz, but I only used 44.1 on my first run through of this set up. |
Eleven Rack Output to Amp | dress4riot | Eleven Rack | 1 | 03-26-2013 10:59 AM |
Eleven Rack Output Question | Bill Denton | Eleven Rack | 1 | 09-09-2012 11:06 AM |
Eleven Rack no output HELP US! | Markownage | Windows | 3 | 08-04-2012 06:47 PM |
No headphone jack output - Meters showing output | Hotcrazyfruit | Eleven Rack | 6 | 05-06-2012 12:09 PM |
003 Rack - Alt Mon Output to Headphone Amp? | lowlights | Windows | 4 | 10-17-2011 12:04 PM |
