Old 03-13-2007, 05:33 AM
Sydes Sydes is offline
Default External Devices have no sound.
I've recently upgraded to pro-tools and I've been happily using software instruments. I re-wired my setup so that I can also incorporate my hardware synthesizers into pro-tools and I can't get any sound output to my monitors from them. I set all my machine to repeat the demo on the hardware synths so I have constant sound, played about with the channels and volumes but no luck!
This does sound like something simple & I hope it is. Can anyone offer advice?
Another issue I've been having is that whilst pro-tools is playing back my project, I cannot play an MP3 (or any other audio file via another application) simultaneously. As pro-tools is now my primary sound device for my Mac then I want all audio to channel through to my monitors. I can only seem to switch between a pro-tools project & other audio via the button "ALT SRC to monitor" ... this seems a little weird.
http://www.asura.co.uk
Old 03-13-2007, 05:47 AM
wheresmyfroggy wheresmyfroggy is offline
Default Re: External Devices have no sound.
You need to describe your setup more clearly. How is your hardware routed to protools? What tracks have you set up within protools?
Old 03-13-2007, 06:01 AM
For simplicity I'll describe the setup for one synthesizer:
I create an 'Audio' track in pro-tools and have it receive input from 'Line 1/2'. My L & R output from my synth are connected to Mic/Line 1 & 2 in my Digi 002 rack. I run a repeated audio demo on my synth and verify that it sounds by plugging the headphones into the synth directly. I have no sound from my monitors and no volume indication in the track volume display in pro-tools. The mute button on the front of my rack is NOT set.
Old 03-13-2007, 06:05 AM
Do the same except use an 'aux' track instead of an 'audio' track and you should be laughing.
Tom
Old 03-13-2007, 06:11 AM
Cheers pal. Thanks for the help.
Is there anyway I can get other applications to sound at the same time pro tools is playing back or is this something I have to suffer?
Jam Sync'ing to External Devices antiphase 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-28-2009 12:32 AM
MIDI devices (external/plug-ins) produce no sound KAJ31 MIDI 3 11-02-2006 11:03 AM
Using external devices.... s0nguy Pro Tools TDM Systems (Win) 0 06-07-2006 12:51 PM
Help: Setting up External devices jackruston Pro Tools TDM Systems (Mac) 1 08-28-2001 12:42 AM
External Devices idehd General Discussion 1 05-20-2001 08:59 PM
