Old 09-21-2023, 11:49 AM
off the wall's Avatar
off the wall off the wall is offline
Default HD Driver 2023.9 STILL Broken.
The new HD Driver 2023.9 is broken as it was in 2023.6.
Reverting back to HD Driver 2023.3 works with PT 2023.9 as it did with 2023.6.
Come on Avid..
File Type: jpg Screen Shot 2023-09-21 at 2.17.52 PM.jpg (31.5 KB, 0 views)
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 09-21-2023, 12:00 PM
filmixer filmixer is offline
Default Re: HD Driver 2023.9 STILL Broken.
That's not happening on my system. Mac mini M2, 32GB, 1TB, Ventura 13.5.2, HD Native card in Avid Thunderbolt chassis to Omni interface. You're running an old system there.
Mark Ettel C.A.S.
Old 09-21-2023, 12:07 PM
Originally Posted by filmixer View Post
That's not happening on my system. Mac mini M2, 32GB, 1TB, Ventura 13.5.2, HD Native card in Avid Thunderbolt chassis to Omni interface. You running an old system there.
Did HD driver 2023.6 work for you? It took Avid about a week to figure out that one was broken on Intel. They pulled it and never fixed it.
Old 09-21-2023, 12:12 PM
Eric Lambert's Avatar
2023.6 worked for me from the beginning. Sorry to see that whatever is giving you trouble has continued without a fix. It can't be just the driver if it's working for so many others (all my coworkers use it successfully), but I suppose you could say that it *is* the problem if it's somehow not playing nice with some other bit of software/hardware. Good luck and I hope Avid gets it sorted.
Old 09-21-2023, 12:16 PM
I was installing PT 2023.9 as I was typing that and it finished though I have not yet installed the 2023.9 Driver. I opened PT and checked a large session and it seems to be fine.
So... if you were somehow able to get PT to play nice with the 2023.6 driver know that it may not be mandatory to install the 2023.9 driver after updating PT.
Old 09-21-2023, 12:21 PM
HD Driver 2023.6 never worked reliably for me and then Avid pulled it and recommended everyone revert to 2023.3. 2023.9 is giving the exact same error as 2023.6 did. 2023.3 is working flawlessly with PT 2023.9.
See my original thread on the 2023.6 driver https://duc.avid.com/showpost.php?p=2672803&postcount=1
Old 09-21-2023, 12:22 PM
Avid is only testing Pro Tools on Mac Pros 2019 or newer and M1 & M2 Macs. Just sayin'
Mark Ettel C.A.S.
Old 09-21-2023, 12:24 PM
Yeah I may be at the end of the line here but will use HD driver 2023.3 for as long as it works.
Old 09-21-2023, 12:31 PM
I don't think there's any advantage to using 2023.9 anyway.
Old 09-21-2023, 01:51 PM
Especially if PT won't even load. :)
Marker behavior broken in 2023.6 Kevin Nettleingham Pro Tools 25 03-30-2024 09:32 AM
PT Ultimate 2023.6 hd driver bug kinghand Pro Tools HDX & HD Native Systems (Mac) 59 09-27-2023 05:27 AM
2023.6 Commit Broken NateAlexander Pro Tools 3 08-20-2023 04:24 PM
Insert Marker Slot broken in 2023.6 off the wall Pro Tools 7 06-09-2023 09:17 PM
Which plug ins are broken in PT 2023.3 and why?!? Franklyn Pro Tools 23 03-31-2023 08:07 AM
