Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 09-01-2020, 09:33 AM
teacherman teacherman is offline
Default Freeze'd audio files??
When I "commit" a track, there is a new file added to the session's Audio folder with a .cm.wav extension.
But, when I "freeze" a track, I don't see any new audio files in the session's Audio folder.
Is this correct? If so, where does the "freezed" audio file get stored?
thanks,
27" iMac; 32gigRam; OSX Catalina 10.15.2; PT 2019.12.0; Apollo x8p; UAD-2-Satellite-TB3-Octo;
Old 09-01-2020, 10:10 AM
daeron80 daeron80 is offline
Default Re: Freeze'd audio files??
thanks,
Yes, it is correct. They're in Rendered Files. Temporary files generated by freezing are placed there with -FZ appended to the filename. These files should disappear when you unfreeze a track, or more likely when you close a session after unfreezing.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 09-02-2020, 10:36 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Hey teacherman.
Committing is like bouncing, while freezing is more like a temporary measure to help you continue working with less CPU usage, especially if you are using lots of hungry plugins. When you are certain you are done with a track you can then commit it. (But I always de-activate and keep the original tracks in case I need to go back to them). Frozen tracks on the other hand are maybe unfinished, and can easily be unfrozen and re-tweaked. On very large mixes the tracks that don't need much plugin 'tweakage' can be frozen to conserve CPU, and unfrozen when the need arises.
The ability to freeze tracks is IMO the most powerful innovation that has happened to PT in a very long time.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Rendered freeze files in Pro Tools 12.6 LSinBTonez Pro Tools 12 11 02-04-2019 08:02 PM
Track freeze is adding 1 minute of audio to files lancemcv Pro Tools 12 2 02-23-2016 08:19 PM
Freeze Files....Are They Useless? Kon Alexiou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-24-2007 08:42 PM
freeze when locating files in 5.1 drumixer Pro Tools TDM Systems (Mac) 1 04-22-2004 02:02 PM
Freeze Scanning Program Files..PLEASE SOMEONE? dnev Digidesign Hardware & Software 3 10-28-2000 10:44 AM
