Old 07-13-2020, 01:08 PM
teacherman teacherman is offline
Default adding a 2nd 192 to my PT rig ??
I'd like to add a 2nd 192 I/O to expand the number of inputs and outputs.
Is it just as simple as connecting a DigiLink cable from the Expansion Port of the Primary 192 to the Primary of the second 192 ??
thanks,
27" iMac; 32gigRam; OSX Catalina 10.15.2; PT 2019.12.0; Apollo x8p; UAD-2-Satellite-TB3-Octo;
Old 07-13-2020, 01:11 PM
Default Re: adding a 2nd 192 to my PT rig ??
If that 192 is the only device on that DigiLink chain then yes it's that simple.
JFreak's Avatar
JFreak JFreak is offline
Yes. You may also connect a cable from 2nd card to 2nd interface primary, but as DigiLink is 32 i/o you can daisy-chain two boxes.
Janne
Old 07-13-2020, 01:42 PM
Oh oops forgot you need to run loop sync between the boxes... but still simple.
Open up the 192 IO user guide if unclear on loop sync.
Remember digitest is your friend. Any issues swap the new box with the old and test that.
Old 07-14-2020, 11:34 AM
Excellent! Thanks for the info!
adding mp4's breeze38 General Discussion 0 06-02-2016 09:58 AM
Adding DSP Help Jarico Pro Tools TDM Systems (Mac) 2 03-27-2008 09:10 PM
Adding a Sub to the mix. pinstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-26-2007 02:51 PM
Adding HD to G3 rusmooth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-20-2005 08:33 AM
Adding HDs, what would YOU do? Sugarite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-10-2001 05:55 AM
