Old 11-20-2019, 12:35 PM
teacherman teacherman is offline
Default Bouncing multi tracks (individually?) at the same time
I've got a session of 20 tracks.
I have a song that is 4:00 mins in length and that is comprised of 20 audio tracks.
Is it possible to bounce all 20 tracks to individual files all at the same time...this would take about 5 mins total.
Or, do I have do (20) separate bounces??....errrrrr... that would take about about an 90 mins to do that...
thanks,
27" iMac; 32gigRam; OSX Catalina 10.15.2; PT 2019.12.0; Apollo x8p; UAD-2-Satellite-TB3-Octo;
Old 11-20-2019, 12:47 PM
Panacci Panacci is offline
Default Re: Bouncing multi tracks (individually?) at the same time
Consolidate all the tracks and then go into your audio folder of the tune and you should see the time you consolidated. Take those tracks.
2009,2012 8 Core Mac 5.1, (32 gigs Ram), MSI Radeon 570,s 2011,17 MacBookPros , 828MKIII Hybrid, 828X , 8Pre, OSX Mojave 14.6,High Sierra 13.6, DP11, PT2024.3 , Peak 7, Logic 9 ,WaveLab 11,Cubase Elements 11,Reason 11, DSP-Quattro 5.5 ,many plugins , mics and synths. http://www.panaccimusic.com
Old 11-20-2019, 01:01 PM
amagras amagras is offline
If you have used plugins and automation then I would commit with all boxes checked, then go to the clip list (with the new tracks selected) and do right click export as individual files so you get the export dialog box.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 11-20-2019, 01:02 PM
I did consolidate. But, the session is @ 48K/24 Bit. The client wants all the individual files to be 44.1K/16 bit. So, I do have to do the bounce to make the conversion.
Old 11-20-2019, 01:18 PM
JFreak's Avatar
JFreak JFreak is offline
First of all, you can only bounce outputs, not tracks. So if you wish to bounce your 20 tracks you need to have 20 outputs set for your tracks. If you haven't set it up like that in your mix, you need to bounce all tracks individually.
Janne
Old 11-20-2019, 01:19 PM
JFreak's Avatar
This is as close as you can get with the OP intention. But then you need some batch processing to change bit depth and/or sample rate.
Janne
Old 11-20-2019, 01:21 PM
JFreak's Avatar
I think it is Ultimate-only feature but you can have more than one bounce source on a single bounce job. But as I said, before that you need to have multiple bounce sources (outputs) and not just have 20 tracks routed to 2-track master.
Janne
Old 11-20-2019, 01:23 PM
Okay, I guess I'll have to bill the client another 90 mins of studio time....
Old 11-20-2019, 01:42 PM
Sorry forgot about commiting. What about saving as an AAF after commit
Old 11-20-2019, 01:56 PM
Prabha Prabha is offline
This kind of feature is what PT has been missing and other daws do (like cubase)
PC i79700K 4.8Ghz 32Gb ram Nvidia1050
Win 10 64
SSL MX4
Bouncing multi-channel audio altoidboy Pro Tools 11 14 04-22-2014 12:46 AM
Time remaining stuck while bouncing! It takes twice the time Retinal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-10-2008 08:33 AM
Bouncing tracks - taking a long time Gonkboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-26-2007 03:02 AM
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Post - Surround - Video 0 06-08-2007 09:06 AM
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Pro Tools TDM Systems (Mac) 0 06-07-2007 02:54 PM
