Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 05-09-2014, 10:53 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Windows keeps changing my default interface setting
Two things you can try here.
One is to make sure you are using the latest drivers for your onboard audio hardware. If not, update the drivers.
Second. Do you have speakers or headphones or something plugged into whatever you are setting as the default device? If not, that may be your problem. A lot of the newer motherboard audio devices have automatic jack detection, which looks to see if the current, default audio device has something hooked up to it. When your system boots, if it doesn't think the default device is actually being used, it will default to the next one, which in your case is the Fast Track. So, you may want to try setting your default device to the onboard audio, then connect some speakers to it and see if your problem goes away.
Will
System Details
Old 05-09-2014, 02:41 PM
DC-Choppah's Avatar
DC-Choppah DC-Choppah is offline
I do have the jacks of the mobo audio output connected to an input channel of Mackie mixer.
I resinstalled the mobo drivers, and the device manager claims I have the latest.
But I think you are on to something. So now I disabled one of the two the audio devices that shows up. So now the only one that is enabled is the one in use (VIA).
So far so good. I have the VIA device set as default.
I can open PT in any sample rate, stream audio no problem, and the machine has not switched the default setting yet.
DC-Choppah's Project Studio:
ASUS PRIME Z390-A / Intel i7 rackmount PC
Windows 10 home 64 bit
Pro-Tools 11.3.1
AIR Instrument Expansion Pack v2
WAVES Platinum plugin bundle
Tascam US-16x08 Interface
100% Analog real time monitoring 16x4
Yamaha 16 channel MG16XU Analog Monitor Mixer
Yamaha MX-88 / Novation XiO keyboards
Mackie 4-channel headphone amp
Adam A8X monitors
Blue / Shure, etc. microphones
Estonia 6' 8" Parlor Grand Piano
Yamaha Studio Drum kit
https://www.dc-choppah.com/
Old 05-22-2014, 06:15 PM
DC-Choppah's Avatar
OK. It's been a few weeks with no problems. Today, something changed the default audio device back to the Ultra 8R.
Pro-Tools 11.3.1
Adam A8X monitors
Old 05-26-2014, 09:47 PM
Emcha_audio's Avatar
Do you have auto updates on per chance?
Manny.
Wave-T.com
Old 05-27-2014, 01:47 PM
popajoe popajoe is offline
Can't lower the buffer size for HD Native & Omni with 3rd party DAWs?
Hi' if may add in DAW's like CB you can check release driver when application is in background/or auto release for some DAW ;Do this for all daw's an plug's like standalone! /also dvd/brun suite's that you can't set what it use's/reason they lock on to the best audio/video device in your system and can also causes I/O an interface connection's problem or setting Hz change's
Have fun not problems
popajoe
PS: something i forgot that you may know but some may not ; on PC's we must keep a set of speaker of some type connected at all times ; or your OS will switch to the next interface that's on.even win you have disable it there it will keep changing back this can happen in session to if you unplug or turn off the speaker we must have a speaker connected for OS on-broad sound card to work.
  #16
Old 06-02-2014, 07:54 PM
DC-Choppah's Avatar
Yes I do.
And since y last post, Windows has not changed the default device. But I also see that no new updates were added since 15 May too.
Hmmm....
Pro-Tools 11.3.1
Adam A8X monitors
  #17
Old 06-02-2014, 07:56 PM
DC-Choppah's Avatar
Thanks for that. The motherboard audio outputs remain connected to my mixing board at all times during this.
Pro-Tools 11.3.1
Adam A8X monitors
  #18
Old 06-03-2014, 02:35 PM
Bill Denton Bill Denton is offline
Do you know what the "default audio device" is?
Okay, I'll help...it's the device Windows uses to play audio when you don't tell it to use something else.
If something wants Windows to play audio, it goes to the default audio device.
If there is no default audio device, Windows will look for ANY audio device and make it the default audio device.
Pop quiz...
You have three audio devices, named 1, 2, and 3.
You have Device 2 set as your default audio device.
You disable Device 1 and Device 2.
You play a YouTube video and hear sound.
Which device is now your default audio device?
And like with every other pop quiz, there's a Bonus Question...
Does Pro Tools even give a wooly rat's ass what your default audio device is?
And JFTR...everything you need to know is in this post...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
  #19
Old 06-04-2014, 06:01 AM
Hi' just make sure your mix broad is on before start up or it will change .
  #20
Old 06-04-2014, 02:09 PM
popajoe
I learned never to say "never" a long time ago, but I've not heard of such a thing in my 25 years in IT (exclusively MS-DOS and Windows).
My own music computer has been running for four years with all onboard sound devices disabled, and the only speakers are the ones connected to my 003 Rack. My 003 is my "default audio device"...that's how I listen to YouTube and CD's...no problems yet...
X
Bill in Pittsburgh
003R+ as Default Interface in Windows 7 x64 testing1two 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-21-2010 05:32 PM
Changing Default Settings...possible? quangaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-20-2007 07:05 PM
Changing from default tempo haldude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-05-2004 07:53 AM
Changing default send level? Great Divide Studios Tips & Tricks 4 03-26-2002 11:03 AM
Changing the input default? bassmac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-02-2001 06:03 AM
