Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
  #21
Old 09-30-2013, 03:20 PM
Koss64 Koss64 is offline
Default Re: Fast Track Pro out of order after last driver update
I try the last 5.xx driver , its look like want to work normally . Independendtly I relieved , if i could take back firmware 1.0.0
  #22
Old 10-22-2013, 12:08 PM
Vincenzo87 Vincenzo87 is offline
Update Please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
  #23
Old 10-27-2013, 10:34 AM
danbruma danbruma is offline
I have the same problem with my m-audio Fast Track Pro. Pleas update the firmware/driver!!! The noise that i hear from my KRK speakers appears after i updated the firmware. The nois is on my laptop and computer, so I am sure that this is a driver problem.
  #24
Old 10-28-2013, 10:52 AM
nationalcmd nationalcmd is offline
I've got the same Probleme!
Win 8 64 bit
Six Core Am3+ CPU
8 GB RAM
Fast Track Pro isnt recognized by my PC after the last Firmware Update .
Used several different USB-Ports.-
Tried to use it with extra 12v Power supply cable,
even downgraded my current M-Audio driver. Nothing works. Always the same problem...
The yellow Triangle and the nasty windows-sound.- Showing up ~every 3 seconds.-
appears and dissapears as unkown devide in the device manger.
M-Audio Driver Control Panel:
bottom left side of the GUI:
Driver: 6.1.10
Firmware: (no display/empty space)
[Hardware not connected | no streaming]
Maybe i've got a clue: I remember disconnecting my Device to late while the firmware update was in progress! I was expecting another dialogue-box like "unplug your devide now!" but then the update already started :/
I guess i have a half installed firmware on my device
PLEASE help us, AVID-Support !!!
greetings from Germany!
  #25
Old 10-31-2013, 08:21 AM
Really no solution or help?
  #26
Old 11-01-2013, 06:20 AM
JoelG's Avatar
JoelG JoelG is online now
I have asked for this to be looked into. But, you might want to actually contact support, these forums are user-to-user:
"Please note that the Pro Audio Community forums, are not an official support
channel for Avid. If you require direct technical assistance, you should contact Avid Customer Success who can then advise on support programs and offering available
– Avid Support (www.avid.com/support/) or the Avid Knowledge Base Online Support
Center for free assistance.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
  #27
Old 11-03-2013, 10:54 AM
pawelq pawelq is offline
Same problem.
I have been using my Fast Track Pro primarily as a playback audio interface since November 2008, on three successive PC computers and several windows systems. It may have started with Windows XP, can't remember at this point, definitely went through Vista 32-bit, 7 32-bit and 7 64-bit. I always output via Line 1/2.
I had no problems until I started using the third computer two weeks ago. I installed Win 7 64-bit (exactly the same as on the computer 2) and the current version of M-Audio driver (which included firmware update). Which seems to be different from the version I had previously, I can tell that the UI has changed.
I experience a variety of problems.
1. The interface will just stop playing or responding to any audio playback program (Spotify, IE/Youtube, foobar2000). A reset by going to Sound/Playback Devices and disabling "M-Audio Fast Track Pro Line 1/2" followed by re-enabling is needed.
2. In one case I tried to reset by switching the FTP off and on, this produced blue screen.
3. In one case a digital noise correlated with sound occurred while playing a YouTube video. Sort of like byte swap, or something like that.
(problems 1, 2, and 3 typically occur not during playback, but after playback was paused or stopped and then enabled again).
4. While playing some games (but not other games) the sound will either disappear all of sudden, or begin to stutter for a second or so, and then either recover or disappear. After sound has disappeared, it may re-appear after a few or a few tens of seconds, but this may depend on the particular game's ability to reset the driver.
All other drivers on the system are up to date.
None of the above has ever occurred with computers 1 and 2, which ran different systems and earlier FTP drivers.
Sandra report:
SiSoftware Sandra
ID
Host Name : *******
Workgroup : WORKGROUP
Computer
Model : ASUS All Series ASUS MB
Serial Number : System Ser**********
Chassis : Desktop
Mainboard : ASUS H87M-PLUS
Serial Number : 1304106********
BIOS : AMI (OEM) 0306 04/07/2013
Intel vPro : 9.00.01.1333
Total Memory : 8GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i7-4770S CPU @ 3.10GHz (4C 8T 3.59GHz/3.9GHz, 3.6GHz IMC, 4x 256kB L2, 8MB L3)
Socket/Slot : FC LGA1150
Chipset
Memory Controller : ASUS Core (Haswell) DRAM Controller 100MHz, 8GB DIMM DDR3 1.6GHz 64-bit
Memory Module(s)
Memory Module : Kingston 99U5471-036A00LF 8GB DIMM DDR3 PC3-12800U DDR3-1600 (11-11-11-29 5-40-13-6)
Video System
Monitor/Panel : Dell Computer DELL U2713H
(2560x1440, 27.2")
Monitor/Panel : Dell Computer DELL 2007FP
(1600x1200, 20.2")
Video Adapter : ASUS HD7750 Series (8CU 512SP SM5.0 800MHz, 1GB DDR5 4.5GHz 128-bit, PCIe 3.00 x16)
Graphics Processor
OpenCL GP Processor : ASUS HD7750 Series (512SP 8C 800MHz, 1GB DDR5 4.5GHz 128-bit)
Compute Shader Processor : ASUS HD7750 Series (512SP 8C 800MHz, 1GB DDR5 4.5GHz 128-bit)
Storage Devices
KINGSTON SH103S3240G (240GB, SATA600, SSD) : 224GB (C:)
Seagate ST2000DM001-9YN164 (2TB, SATA600, 7200rpm) : 2TB (D:)
Seagate ST2000DM001-9YN164 (2TB, SATA600, 7200rpm) : 2TB (E:)
ASUS DRW-22B1LT (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:)
Logical Storage Devices
KingstonSSD (C:) : 223GB (NTFS) @ KINGSTON SH103S3240G (240GB, SATA600, SSD)
Barra1 (D:) : 2TB (NTFS) @ Seagate ST2000DM001-9YN164 (2TB, SATA600, 7200rpm)
Barra2 (E:) : 2TB (NTFS) @ Seagate ST2000DM001-9YN164 (2TB, SATA600, 7200rpm)
Optical Drive (G:) : N/A @ ASUS DRW-22B1LT (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS Lynx Point LPC Controller
LPC Legacy Controller 1 : T0 C8-03
Audio Device : ASUS Lynx Point HD Audio Controller
Audio Device : ASUS Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series]
Audio Codec : ATI (AMD) HDMI Audio
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : ASUS Lynx Point 6-Port SATA AHCI Controller
USB Controller 1 : ASUS Lynx Point USB xHCI Host Controller
USB Controller 2 : ASUS Lynx Point USB Enhanced Host Controller #2
USB Controller 3 : ASUS Lynx Point USB Enhanced Host Controller #1
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP Deskjet F300 Series (1200x1200, USB, Colour)
Scanners and Cameras
Scanner : Hewlett-Packard HP Deskjet F300 (Scanner, 2400x2400, USB)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet)
Wireless Adapter : Belkin USB Wireless Adaptor (802.11g (ERP), AES-CCMP, 130Mbps)
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 7.3
  #28
Old 11-11-2013, 04:18 PM
bump?
  #29
Old 11-15-2013, 05:32 AM
froschhund froschhund is offline
I have the same problem with Fast Track Pro on my new PC. On my ~4 year old Sony Vaio Notebook, it works fine, which is strange since both computers run the same OS (Windows 7 64bit), even installed from the same DVD. The audio stops playing randomly, ranging from about 2 minutes up to 1 hour or so, sometimes accompanied by a distorted noise.
However, i found a SOLUTION to this problem that works for me. It's rather simple: Don't use the crappy drivers by Avid/M-Audio. I tried every driver version from 6.0.2 up to the newest one that updates the firmware. None of them works! Trust me, save your time.
What I did:
1. Go to the Windows Device Manager, find the Fast Track Pro device under "Audio", right-click and uninstall the drivers via the uninstall-button in the "Drivers" view.
2. Upon the next reboot, Windows 7 64bit automatically detects the device as "Fast Track Pro" (without "M-Audio") and installs some generic drivers.
The latest driver is from July 12th 2013, Version 6.1.7601.18208, provided and signed by Microsoft. You can again view this information in the Device Manager (same view as in step 1).
Now the Input/Output channels are listed under some generic name (something like "Analog Out 1" and "Analog Out 2", which correspond to "Line Out 1 & 2" and "3 & 4". You can rename them in the Audio settings and make "Out 1 & 2" the default playback device again.
If you just use your device to play audio, that's it. However, if you want to use it for recording, there's still another problem to solve.
3. Unlike in the M-Audio Control Panel, you can't adjust the buffer size and get the generic Windows ASIO driver down to a reasonable latency (the best I could achieve was 40ms, which is of course too much). To solve this, I installed the latest "asio4all" driver (http://www.asio4all.com/ just a single .exe file to install), which offers the ASIO4ALL driver and comes with a Control Panel that lets you adjust the buffer size again.
I made a screenshot that shows my settings: http://i41.tinypic.com/2mgtbtc.jpg
On my machine (Intel Core i5, 8 gigs of RAM) I can set the buffer size to about 192 (= 9ms) with no glitches at all. For recording, I switch to 128 (= 7ms) which is totally fine for me. Lower values result in noticeable glitches during playback (especially in a project with a few "heavy" VST instruments) but this was also the case with the original drivers.
Until Avid or whoever comes up with a driver fix, this is an acceptable solution for me and I hope that I could help a little.
  #30
Old 11-22-2013, 06:33 AM
Tha_Clinic Tha_Clinic is offline
There's seriously still no solution to this? It happened to me last night and has me so frustrated because i just set up a new laptop to record on. This needs to be solved.
win 8 installs own driver for Fast Track Pro clsbd_lou General Discussion 2 02-12-2014 06:49 AM
Driver problems with Fast Track Pro USB musictomyears FireWire & USB Audio Interfaces (Mac) 1 10-15-2013 12:16 PM
Fast Track Ultra 8R Driver Beto Chaves macOS 1 10-13-2013 02:53 AM
Problemo of new Fast Track 6.1.12 driver tkrojam FireWire & USB Audio Interfaces (Win) 2 07-20-2013 10:17 PM
