Mbox Pro hissing, crackling, master volume issues
As I connected my Mbox 3 pro to Yamaha MSP 5 monitors, there was a lot of hissing and crackling noises. This is coming from all monitor outputs (1-6). So far I have used headphones and no issues noticed when using headphones.
This hiss and crackle are there even if PT is not running. Another thing I noticed is that the master volume is not responding real time. It take about 5-6 seconds to change the volume levels after you mote the nob! I used both PT and Ableton and found the hiss & noise issues is there. As I browsed through the forum, I see that many people have experienced this. I believe this is a hardware fault. But before I go back to the vendor, I would appreciate if any one can give some tips.
Jonz | Al Shams TV Production LLC Mbox 3 Pro | Pro Tools 10.3.7 | Novation Impulse 25 | Novation ZeRO SL MKii | Mackie VLZ3 | Yamaha MSP 5 | Rode NT1a | Shure SM58 Intel i7 Quad Core, 8 GB RAM, 128 GB SSD sys drive, 1 TB HDD, Nvidia Quadro 600 |
Re: Mbox Pro hissing, crackling, master volume issues
uninstall and reinstall the drivers, also make sure all the optomizations are done. At the same time could you post a sandra report please?
Update
I got SIIG firewire card bought from ebay. All my above mentioned issues solved after installing it.
Good to hear thanks! Would you mind putting this [solved] in your title please?
I took sometime to post a reply with updates. I guess I was too quick in saying 'all' the problems solved. I still have one really annoying issue. Hissing, crackling, white noise from all 1-6 line output, though it came down little bit when I changed my firewire card. From the headphone out this is not heard.
This problem is not yet solved and I see many more people having same issue. If I or my clients are not able to hear clean sound from the monitors, this box is of no much value! Hope Avid listens to people.
Could this be a ground issue? I had/have a similar issue with my ProFire 2626, I ended up chassis grounding it to another piece of rack gear that had a 3 prong power cable to ground it.
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Thanks Joel, I will try that. I thought a ground issue will give a constant hum not crackling and white noises.
I forgot to mention one more thing. I could here some small swish sounds when I am loading pro tools. Also some sort of sound when the mouse is moved.
I've had the mouse noises myself before. Do you have a wired or wireless mouse? This is likely EMI. If you're using a wired mouse, be sure the wire doesn't come near your speakerr wires.
Joel
MBox 3 Pro Master Volume | anackman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 19 | 09-10-2012 02:56 PM |
Crackling & Hissing in Pro tools 9.0.6 | [email protected] | Pro Tools 9 | 1 | 04-14-2012 10:33 AM |
Hissing Crackling | m_atrix13 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 02-06-2010 08:08 AM |
hissing/crackling noise | dj nik bean | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-18-2006 03:51 PM |
Hissing Compressors on Master Fader | rnt_u_listnng | Pro Tools TDM Systems (Mac) | 1 | 07-03-2003 05:32 PM |
