to delete transfuser internal factory presets ...
hi ,
i want to access and delete some factory presets internals of transfuser like loops, kit, etc ... where is the folder to do that please ? thanx |
Re: to delete transfuser internal factory presets ...
Program Files\Common Files\Digidesign\DAE\Plug-Ins Settings
Mac Library/Application Support/Digidesign/Plug-Ins Settings filosofem |
no i try plugin settings before this thread but i dont reach the all the loops, kicks , kit etc of factory transguser preset so its not the good folder ..
and for your first suggestion with "program files" etc i suppposed its for pc no ? |
Filo showed you both, not sure what else he could have done to help you my friend.
I work with amazing people who do incredible things. Founder of the Expert Sites. |
Are you talking about presets or the actual audio content??
Presets can be deleted from the preset menu..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
you mean both... the other "program files "etc is for pc right ?
anyway i cant beleive it is not possible to delete audio elements in transfuser ....? |
I do know on Mac, the digidesign content for their plugins gets installed in the same folder where the "ProTools" and "Documentation" folders are... just do a search on your peecee for "transfusor", and find any folders with that name. The one that has the .big file(s) is what you are looking for... BUT.... If there is only one large .big file, then it probably has ALL the transfusor factory content in it as a single monolithic file, and you can't separate out individual files.. I think...
metascanner, Presets are Plug-Ins Settings and not audio. filosofem |
I have a similar question... I would love to add my personal list of sounds to Transfuser Audio Drums Samples lists...
I also searched for the Folders containing the Audio Samples but I did not find them... The only way to use my own "Snares", for example, seems to be to Drag & Drop the sounds to the Drum Pads... But it is very slow... Instead with the internal factory sounds, you can select a PAD, and scroll in 1 second hundred sounds!.. I would love to do this with my sounds, but I do not know if is possible!!.... I tryed to drag a folder to the Pads, but Transfuser crash!.. |
thnax for your great help anyway my friend ! |
Transfuser Factory Files | lhawkins | Virtual Instruments | 3 | 04-10-2012 01:44 PM |
sansamp and transfuser presets and samples | undadogz | Pro Tools 9 | 0 | 10-12-2011 01:56 PM |
Transfuser presets ... | metascanner | Virtual Instruments | 43 | 09-04-2008 07:01 AM |
Transfuser - hor to delete user tracks? | remute | Virtual Instruments | 2 | 08-12-2008 08:31 AM |
Any way to delete saved Waves presets? | crizdee | Pro Tools TDM Systems (Mac) | 3 | 06-27-2007 06:32 AM |
