M-Audio FastTrack USB - Windows XP - Not working :(
I've read the forum and gone over a lot of things but still get the 'unable to locate device' error when launching PT.
AMD 3800+ CPU downloaded the patch. Got 2x HardDrives. (no RAID) Using 3 USBs - Keyboard, Mouse, M-Audio FastTrack. Tried the 7.3 CD that came with it and tried the latest 7.4 download. At first PT wouldn't install saying I needed to update windows (XP SP2), I downloaded an update, then it let me install. It works fine in Audition, but I wanted to see how Pro Tools works with it. |
Re: M-Audio FastTrack USB - Windows XP - Not working :(
Do you have the most recent FastTrack drivers from the M-Audio website? (The current one as of this post is 5.10.00.5114v4)
Just deleted the old drivers and installed the new ones above.
The LED is lighting up on the front of the USB FastTrack, but when I double click the M-Audio icon in the system tray, it says 'not connected' on the pop-up in the top right. I can open an audio file in winamp and it will play! But now Audition isn't recognizing the device as well as PT + the driver software Tried the 'disable USB power' as well, but that didn't do anything: http://www.m-audio.com/index.php?do=...d25acbdd34f27f Also disabled the network and on board audio, but that didn't do anything. |
Has anyone else got any suggestions please?
Did you uninstall the old driver through the Add Remove Programs or did you just deleted it?
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
Via Add / Remove programs, first, that didn't work.
Then I went to install the driver again and it came up with 'Delete drivers' so I did that as well and re-installed, but that didn't work either. |
m audio fasttrack pro output pot problems | jbreeze | FireWire & USB Audio Interfaces (Win) | 4 | 02-11-2015 02:31 AM |
M-Audio Fasttrack Tracks 1+2 noise | gswitz | Pro Tools M-Powered (Win) | 1 | 12-14-2012 09:45 AM |
Pro Tools M-Audio 9 and Fasttrack Interface Not Working for Asus G73JW laptop | EndlessRender | Pro Tools M-Powered (Win) | 0 | 04-02-2012 06:20 PM |
Help Please - M-Audio FastTrack/Pro-Tools M Powered | The Shamrock | General Discussion | 0 | 03-24-2011 07:19 AM |
Recording with M-Audio Fasttrack USB and 7.4 | greg1 | Pro Tools M-Powered (Win) | 3 | 04-14-2008 01:34 PM |
