Old 01-15-2007, 07:46 AM
JFreak's Avatar
JFreak JFreak is offline
Default HOWTO, audio file automation during record pass
Hi there,
Is it not possible to write automation to audio track while the track is record enabled? I recently mixed a TV live show and naturally recorded all audio tracks for possible future use. All tracks' automation mode was "write", but only AUX track automation was written to the session. What did I miss? How can I write automation to audio tracks while I record? Do I really have to create a VCA master for every audio track and write automation there?
I should probably had to suspect losing automation on audio tracks as the automation "write" button looked different on audio tracks compared to aux and master tracks, but I didn't. Now I'd need some clear advice on how to do this next time...
Janne
Old 01-15-2007, 09:00 AM
garret garret is offline
Default Re: HOWTO, audio file automation during record pass
Yes automation is disabled for audio tracks in rec mode i'm afraid. What you say about a vca for each audio track would do the trick or route each audio track to an aux and write the automation there. The advantage is with the vca though as you can coeolesce the automation easily after wards.
IMDB
Low/High Pass Filter Automation Help Funkle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-08-2010 09:23 AM
Record disabling after each pass Oli P Pro Tools TDM Systems (Mac) 2 04-04-2008 08:31 AM
automation problems. the first pass doesn't stick londonsoundbloke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-03-2007 05:14 AM
Will 002R pass audio without Record Enabled Track? The Dougfather 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-04-2007 07:10 PM
automation problems. the first pass doesn't stick londonsoundbloke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-03-2007 08:21 AM
