trying to connect an effects unit w/002
i am trying to connect a outside compressor and/or an effects unit to the 002 rack. How do i connect it to the 002 in order to have effects on my mic while recording?
Re: trying to connect an effects unit w/002
You can't. You would need to use a separate preamp before the compressor to acheive quality results.
Technically, you can do it pre-record with the compressor hooked up as an insert, and using an aux track for initial input bussing to an audio track, but that causes triple A/D->D/A->A/D conversion that most people view as being undesireable. With the specs of today's recording gear you don't really need to compress pre-recording though, just set it so that it doesn't clip, and if it needs compressing, do it later with plugins (or outboard, if you want to).
Analog Insert/Aux Effects Unit Bus Question | sseccajd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 01-17-2012 04:50 PM |
Eleven rack as effects unit for pc | singtall | Eleven Rack | 3 | 07-20-2011 07:34 AM |
Can you hook up external effects unit with Mbox1? | brlfvr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-27-2006 07:05 PM |
how does the PT mic pre unit connect? | willbgoode | Pro Tools TDM Systems (Mac) | 4 | 10-23-2004 09:44 AM |
The best way to connect an external EQ/comp unit to 001 | ISedlacek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 05-20-2003 04:16 AM |
