Old 06-28-2020, 12:41 PM
teacherman teacherman is offline
Default Avid 192 I/O question ???
A friend of mine is running PT9/HD3 with an Avid 192 I/O.
Installed in the 192: Bay-1 is the 8 channel analog Input card; Bay-2 is the 8 channel output card; and Bay-3 is the 8 channel Digital I/O card.
Currently, he has connected 16 channels of mic pres connected to the 8 Channel of Analog IN and 8 channels using the ADAT IN on the Digital I/O card.
My Questions: is it possible to use the OPTICAL ADAT IN via the Enclosure Connector to get another (8) channels of input into Protools? Giving a total 24 inputs simultaneously?
Thanks,
27" iMac; 32gigRam; OSX Catalina 10.15.2; PT 2019.12.0; Apollo x8p; UAD-2-Satellite-TB3-Octo;
Old 06-28-2020, 01:40 PM
Default Re: Avid 192 I/O question ???
Thanks,
Absolutely not, this is a 16x16 interface defined by the TDM2 bus protocol that Digilink uses. The 192 IO manual does a good job describing how you can use the 192 IO chassis and card digital IO connections. The solution is you buy another 192 IO, they can be found very chealy.
Old 06-28-2020, 01:57 PM
JFreak JFreak is online now
The limitation is in the DigiLink, which carries 16+16 for two daisy-chained interfaces for total of 32+32. You just need to choose which 16+16 you wish to use per interface.
Old 06-29-2020, 07:27 AM
Okay, thanks for the info.
Though, what is the difference in the OPTICAL ADAT that comes standard on the Enclosure card and the optional ADAT IN on the optional Digital Card?
Old 06-29-2020, 07:30 AM
No difference. But with 8ch on enclosure and 8ch on card you can have 16ch total if that is what you are looking for, without need for extra digital card. ADAT is limited to 48kHz on 192 interface, no SMUX
Old 06-29-2020, 09:09 AM
All very well described in the 192 IO Manual.... which you need to read. PDFs are a google away.
Old 06-29-2020, 09:34 AM
^^ what he said.
Bug long story short -- only difference between enclosure and digital card connectors is that enclosure AES is 96kHz 2-channel max and has XLR connectors, compared to 8-channel DSUB 192kHz on digital card.
Old 06-29-2020, 12:04 PM
BScout BScout is offline
Some of the info is here and some is incorrect.
There is a difference between the enclosure and the option card optical connectors.
The option card optical port only accepts 48kHz and will SRC to whatever session sample rate you are using. It also only outputs 48kHz. It has realtime sample rate conversion. It is also not switchable to optical SPDIF.
The enclosure optical port has no realtime sample rate conversion. It is also switchable to optical SPDIF (2 channel) instead of ADAT where it can go to 96kHz. However, in ADAT, it is also restricted to 48kHz.
Overall, ADAT on the 192 interfaces is restricted compared to other hardware makers who do >48kHz (DS/QS). I remember back when these were everywhere people thinking they were doing 96kHz just because their session was set that way but transferring via ADAT.
The Avid IO line of interfaces rectified this.
[IMG] code is Off
Avid PRE HPF question Armando Pro Tools HDX & HD Native Systems (Mac) 2 07-01-2019 06:20 AM
Avid i o 8*8*8 question musicmixer04 Pro Tools HDX & HD Native Systems (Mac) 2 06-18-2014 01:29 PM
Avid Standard Support - question for Avid Bo Walker Pro Tools 10 9 12-13-2011 03:08 AM
Avid Pre Question David Correia Pro Tools TDM Systems (Mac) 2 07-24-2011 09:31 PM
Avid 888/24 question maurisebas General Discussion 3 11-14-2001 12:35 AM
